| Reppyboyo |
 Reppyboyo Nearly there...
 Posted: 18:22 - 07 Feb 2010 Post subject: Speed Triple, not starting. |
Hi,
As of Friday by Speed Triple (07, newer ECU type) wont start.
Did nothing to it but wash it, started it up fine try dry it off a little and turned off a few minutes after.
Forward about 20 minutes, the bike wont start at all.
It tries to, seems to attempt to catch every few turns but simply wont start.
Battery got low, charged it over night and tried again today, still no starting.
Got the tuneboy out, no errors, downloaded the same map I had on there already.
Reset the ISCV, which seemed to help a little as it catched more than before.
Left it half an hour, came back and now it doesnt even attempt to start, pushing the button now gives me a loud click from the back of the bike and the entire thing resets. (tach does its self-diagnostics thing)
Any idea what the hell is happening here?
Only thing I`ve gained is that the battery appears to be on its way out.
As of now, i`ve had the tank off and checked the plugs, they look fine, no water ingress.
https://www.youtube.com/watch?v=Bq-9es0yblc
Vid of the sounds im getting and the 'click'. |
| crackpotterpi... |
 crackpotterpi... Renault 5 Driver
 Posted: 18:59 - 07 Feb 2010 Post subject: |
if you have any doubts about the battery,replace that first as low battery voltages can make newer bikes do "weird"things.Or you could try jump starting it off your car with the current battery still connected.............your original fault after washing it does sound like water ingress somewhere you could try spraying liberal amounts of wd 40 or an alternative water dispersant around all main relay and ecu connections, dont forget the ht leads..........let me know  ____________________ 1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun |
| Poseidon |
 Poseidon World Chat Champion
| Reppyboyo |
| chris-red |
| Reppyboyo |
| SW Motech Shop UK |
 SW Motech Shop UK Scooby Slapper
| Reppyboyo |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 23:14 - 11 Feb 2010 Post subject: |
Bump it . |
| Rob |
 Rob World Chat Champion
 Posted: 00:32 - 12 Feb 2010 Post subject: |
I had a very similar problem with mine and it was the battery... it took a couple of different one's to get it going again, it seems very fussy with batteries and if you're not hitting exactly the right voltage it just doesn't bother starting!
As you've tried a couple now maybe yours isn't the same issue - but it does sound very similar!
The other option is that the top of the engine block by the spark plugs there is a 'rim' around the edge that allows a pool of water to sit around the top of the plugs... that caused a problem for me once and had to put some sealant around to stop the water gathering there.
Anyway - good luck - hope you get her running again!
Rob ____________________ Love is 1050cc  |
| chris-red |
| Poseidon |
 Posted: 10:13 - 12 Feb 2010 Post subject: |
| Reppyboyo wrote: | Yup, stinks of petrol.
Turn the bike on, oil and engine lights remain on as usual, neutral light off.
Press ANY of the buttons on the speedo and the engine light goes out, release the button and it comes on again.
Try to start the bike, fail, engine light is off neutral light is on.
Pretty ANY of the buttons on the speedo and the neutral light goes off, release the button and it comes on again.
What the fuck? |
Sounds like a duff earth... Not had it on the bike, but had it with the car. Turn ignition and all the usual warning lights came on, yet as soon as you try and start the thing, everything went off as if there was no power. Fixed it by replacing the earth terminal. Might be worth checking the earth on the bike and wiggling the connection whilst trying to start it.
Drew ____________________ 1977 Honda CG125
2002 Ducati Monster S4 (currently restoring) |
| neatbik |
 neatbik World Chat Champion
 Posted: 10:50 - 12 Feb 2010 Post subject: |
Yeah, sounds like dodgy wiring to me.. Find all the earth points and visually inspect them.  |
| Reppyboyo |
| neatbik |
 Posted: 19:44 - 12 Feb 2010 Post subject: |
There will be one from the starter motor, check that one first  |
The last post was made 15 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
