Does a 33bhp restricted bike have less acceleration?
Marc_Buck
PostPosted: 14:29 - 30 Jun 2004    Post subject: Does a 33bhp restricted bike have less acceleration? Reply with quote
Will a restricted vfr 400 have less acceleration than an unrestricted one?
Ninja
Caption Abuser
PostPosted: 14:32 - 30 Jun 2004    Post subject: Reply with quote
only after a certain point - initial bottom end should be identical
James
4 wheels transport the Body ... 2 wheels transport the SOUL
jayluvmito
PostPosted: 14:42 - 30 Jun 2004    Post subject: Reply with quote
not if the restictors were to...fall Twisted Evil out...
one day...
loply
PostPosted: 14:43 - 30 Jun 2004    Post subject: Reply with quote
https://www.loply.com/loply/33bhp.JPG
My very unscientific diagram should show how the two bikes will be (roughly) identical up to a certain RPM, at which point the restrictions begin to take effect.
So acccelerating at less than 33bhp on either bike will be identical, only whence the unrestricted bike taps into the 40bhp+ will it be different, though I cant say what revs that occurs at.
Marc_Buck
So where i will be using the speed the most will be the same......that's ok because i do not plan on going 100+ everyday.
Robby
Dirty Old Man
PostPosted: 14:45 - 30 Jun 2004    Post subject: Reply with quote
Yes.
Restrictors make it slower all over the rev range. I had a vfr400 restricted and then unrestricted. It was slower in all ways restricted. And it ran worse.
PostPosted: 14:46 - 30 Jun 2004    Post subject: Reply with quote
Well that will be quite hard to do 100+ as the top speed with 33bhp is about 105mph.
33bhp does affect the bikes perfomance and responce though the entire range, well once you're asking the carbs to let more fuel in but it's being limited by the restrictor you're going to not be accelerating as fast as a un-restricted bike would be.
jay12329
Dr. Evil
PostPosted: 17:21 - 30 Jun 2004    Post subject: Reply with quote
I took my 33bhp hornet round cadwell, it takes a bit longer to accelerate, but is still al ot of fun. So yes a restricted bike will accelerate slower, but 0-30/45 mines still fast, then its still faster than anything with four wheels to 80.
J
Visitor Q
$25 whore
PostPosted: 16:54 - 02 Jul 2004    Post subject: Reply with quote
Dont listen to the nonsense about restricting ANYtHING to 33brake. I rode a divvy 600 for 3 weeks that was restricted to 33brake, was slow as fuck to 40, from 40 to 80 good pickup, then crawled up to about 110. Lurched into corners, etc.
Just kills the bike
Get a 33brake standard bike, such as what i have. It may be weakish, but it feels like it belongs like that.
Mr C
PostPosted: 17:17 - 02 Jul 2004    Post subject: Reply with quote
I've never thought about this but I think the diagram is flawed
The peak power will be in roughly the same place presumably but it will get there slower as the shape of the curve will not change to a flat top as you show it
The line will be at a shallower angle to peak as there is less fuel/air to make power throughout the range
more like this I'm guessing - can anyone confirm?
187.3bhp = 201mph
Marc_Buck
PostPosted: 17:23 - 02 Jul 2004    Post subject: Reply with quote
Will an nsr 125 beat many cars on pull away?
Frost
PostPosted: 17:41 - 02 Jul 2004    Post subject: Reply with quote
I would have thought it would depend on how it is restricted. If the bike is just being starved of fuel/mixture then i would expect it to be as you said and just like a scaled down version of the normal bike.
If the restriction is electronic then it could in theory just be made o run as normal but max out at 33bhp. however i would imagine this to be complicated to program, and that simply restricting power through resticting fuel supply would be the more simple and logical thing to do.
I would expect a 33bhp bike to just lack power throughout the rev range, however i would also expect that in the electronic setup they would not deny the engine fuel at the lower revs as this would effect the tickover and general running of the bike.
i would expect the two lines on the graph to start off level, stay level up to about 20bhp at which point the power of the rstriced bike would start to level off towards 33bhp, where as the full power bike would just keep on going.
jay12329
Dr. Evil
PostPosted: 18:25 - 02 Jul 2004    Post subject: Reply with quote
If i had the money i could get mine dyno'd to find out what the power looks like. I have no problems with it. like i said i managed cadwell fine.
J
Visitor Q
$25 whore
PostPosted: 18:31 - 02 Jul 2004    Post subject: Reply with quote
Just for the crack someone should take a big bored busa and restrict it to 33brake. No really its just as good a bike... Really.
Stupid 33 brake restriction bollocks. Surely a speedo trip that cuts throttle after you hit 70 for two years would be better. But since the top speed limit alledgedly IS 70 they might extend that to everone..........
Shocked
Frost
PostPosted: 18:37 - 02 Jul 2004    Post subject: Reply with quote
Its been tried, apparently the thing was unrideable.
it struggled to pull gears had flat spots everywhere etc
Visitor Q
$25 whore
PostPosted: 19:32 - 02 Jul 2004    Post subject: Reply with quote
My point exactly...
Restrictors just aint cricket. Either dont have em in or ride something 33brake standard.
PostPosted: 20:41 - 02 Jul 2004    Post subject: Reply with quote
Think Mr C is probably correct to an extent. The engine is likely to perform in much the same way as it would if you used no more than, say, 1/4 throttle. It probably would peak at lower revs, but not at the revs that it would produce 33hp when unmolested.
Dr Nick
PostPosted: 00:35 - 03 Jul 2004    Post subject: Reply with quote
J
Take them out, it will be a cdi restriction and 4 permanent washers in the intake manifolds, my dealer decided to keep the parts to derestrict my hornet Confused . So told them i was selling the bike and they handed them over Very Happy .
Best thing i ever did to that bike is take the restrictors out, it maybe illegal, but i doubt the police will ever find it is restricted me being 17 and all.
is that it
tatters
Exxon Valdez
PostPosted: 00:41 - 03 Jul 2004    Post subject: Reply with quote
same hear with my VFR400 and KR1S l,m 17 on a restricted lience no restrictions but if l crash insurance company would,nt be happy Sad
maverick
PostPosted: 23:38 - 09 Aug 2004    Post subject: Reply with quote
I have a VFR400 and it is OK till I get to 10000rpm/135kph and then it starts wallowing around like it is running out of fuel.. Does this sound like a restricted bike to those in the know??
Jim
skyline
PostPosted: 02:50 - 13 Aug 2004    Post subject: Reply with quote
Shocked
in japan (or somewhere like that) they have a speed light on the bike that lights up once you reach 56mph to tell you ur speeding. then once the bike reaches 113mph the engine automatically cuts out. quite a good idea really...
Frost
PostPosted: 02:52 - 13 Aug 2004    Post subject: Reply with quote
I'm supprised they actually let you drive in japan, and dont have a madatory computer controlled system which drives perfectly for you
PostPosted: 10:12 - 13 Aug 2004    Post subject: Reply with quote
I've ridden a few 33hp bikes. Some take it better than others.
For instance Laura's CBR seemed to be well suited to it. You could only just tell that it was a bit faster upto 70 or 80.
A restricted r6 I would say still felt as good as far as acceleration goes as a goose. However if you've ridden an unrestricted one you would know it felt horribly blocked up.
fuzz
PostPosted: 10:38 - 13 Aug 2004    Post subject: Reply with quote
Yes. I was coming off a roundabout in the left hand lane of a two lane dual carriageway. Some geezer in an audi or something was on my right. As hard as he could accelerate to try and over take me, he had no chance, and ended up dropping back behind me! Thumbs Up I know I should have let him overtake but it was to much fun watching his reaction in my mirror Mr. Green
billy whizz
PostPosted: 10:54 - 13 Aug 2004    Post subject: Reply with quote
Had a chat with my cousin over this thread, quite an interesting subject. He works at Ricardo engineering (they design engines) he said the curve would be nothing like the original machine. This is because the power curve of the unrestricted machine depends on the induction circuit remaining exactly as designed (just think about porting and polishing). So if you put a restrictor in the induction circuit you destroy this, also the engine relies to some extent on the fresh charge of fuel air mix to purge the cylinder of exhaust gasses, this effect is also lessened at certain rpm (to do with frequency regeneration so i'm told Confused ) which accounts for the feeling of the bike lurching around.
Taking all this into consideration you can see why an engine designed only to produce 33bhp does it so much better than a restricted one!
Here comes the summer! Smile
The last post was made 21 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 129.7 Kb
