Well im flabbergasted with it !!!!!!!!!
BrianZXR
PostPosted: 21:05 - 08 Feb 2010    Post subject: Well im flabbergasted with it !!!!!!!!! Reply with quote
I maybe being completely dense but i have done everything to make this bike run right and it just aint !!!!!!! .Its a zxr400h and im having an issue with the carbs , cleaned them , blown them out , checked and oiled cables ,checked the inlet rubbers (which are fine) , checked float heights ,main and pilot jets (correct sizes) ,adjusted the pilot screws (which were all out half a turn either way) to two and a half turns out from fully in ,air filter is fine , airbox rubbers are a pain to get back in but they're on and good ,diaphragms looked fine and work as they should ,im at a loss .
Symptoms are this ,,,, when bike is on its stand it runs faster than when its stood up , when stood upright it drops by about 300rpm ,also when coming to a stop and pulling the clutch in the engine holds at 2000rpm then drops to tickover ,but because of the side stand tickover being so much higher it means i have to turn it down which then in turn means when its stood upright the tickover is barely ticking over , , , its driving me mad ,, is there something im missing or is there a happy medium ?, bike runs fine on the road , till i come to lights ,pull clutch in and hey its running high , please tell me ive missed something , thanks for any ideas or help , am at the end ov my teather , aint got a garage so am out in the cold doing everything
Blue_SV650S
PostPosted: 21:16 - 08 Feb 2010    Post subject: Reply with quote
Have you tried simply balancing them?!! Thinking ... if they are fighting one another then you are going to get some odd idling.
BrianZXR
PostPosted: 21:29 - 08 Feb 2010    Post subject: Reply with quote
not done balancing them as yet , havnt got the balancing kit , would there be a way to do them without it ? if i ferked with balancing them could i make it tons worse ? , cant ride it like this , has a stupid loud exhaust and just sounds daft at every junction reving its jewels off , ,, anyway i could fashion a balancing kit ? any hints as to how to struggle through ?
Blue_SV650S
PostPosted: 21:39 - 08 Feb 2010    Post subject: Reply with quote
There is the lolly stick method - google it to find the full write-up Thumbs Up
The principle is to shove some lolly sticks in the carbs and make sure they start tilting/falling at the same time ... it is simple, and bound not to be as good as a proper vacuum balance, but at this point, you are only really looking at 'there or there abouts' sort of solution ...
Give it a go!!! Thumbs Up
There is also the water tube (manometer) method (google that too). Cool
BrianZXR
PostPosted: 09:58 - 13 Feb 2010    Post subject: Reply with quote
thanks for your help , ended up using the drill bit method to get them near to right , will do for now , runs and aint playing up , many thanks brian
Frost
PostPosted: 11:02 - 13 Feb 2010    Post subject: Reply with quote
Try turning the steering from side to side and see if the rev's pick up. Might just be a snaging cable.
The last post was made 16 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 48.79 Kb
