multiple devices from one 12v source - how?
bigup
PostPosted: 11:07 - 09 Feb 2010    Post subject: multiple devices from one 12v source - how? Reply with quote
ok, so im gonna take a feed from my rear lights and want to add multiple devices to it.
i.e.
Starcom Unit
Radio
Heated Grips
Inforad Motorcycle GPS
and maybe more gadgets lol
whats the best way for me to do this?
i was thinking using a scotchlok to splice into the feed, but then i need something that i can add these devices to, maybe a terminal type block? any ideas?
Thanks
neilb
PostPosted: 11:25 - 09 Feb 2010    Post subject: Reply with quote
bigup
PostPosted: 11:43 - 09 Feb 2010    Post subject: Reply with quote
neilb wrote:
See my post in:
https://www.bikechatforums.com/viewtopic.php?t=160361
Currently the second from last one.
This is a relay switched terminal block that switches on/off with the ignition. I just used a Snap-Lock connector from Maplins to splice into the brake light wire:
https://www.maplin.co.uk/Module.aspx?ModuleNo=43076
Not sure how to calculate the power draw with all those devices, but I am sure you have thought of this already! Smile
that sounds ideal mate!
what kind of relay do i need to buy mate? any links to one?
truslack
PostPosted: 12:19 - 09 Feb 2010    Post subject: Reply with quote
Don't splice into cables, that's a good way of corroding your loom. If need be, use a piggyback spade connector to feed a relay.
neilb
PostPosted: 14:21 - 09 Feb 2010    Post subject: Reply with quote
neil.
PostPosted: 14:47 - 09 Feb 2010    Post subject: Reply with quote
+1
truslack
PostPosted: 15:12 - 09 Feb 2010    Post subject: Reply with quote
It may be worth using the relay to supply a 4/6 way fuse box, and run each item from a separate fuse.
supZ
PostPosted: 15:21 - 09 Feb 2010    Post subject: Reply with quote
thats EXACTLY what im building at the mo.
ordered a little black plastic box from maplin, i have a standard automotive relay and bought a 4 way mini fuse box from halfrauds yesterday. https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_379579_langId_-1_categoryId_165562
im going to solder a metal strip across one side to join the connections and the relay 'on' circuit will feed into one of the connections.
im going to build it all into this little box with just the connectors showing allowing it to be weatherproof and you'll be able to mount it whereever you want. plugging things in is as simple as wiring up a spade connector and pushing it on Smile
i'll post back once i've finished it, just waiting for the box to arrive then i'll be building it this week.
CBR954RR - Daily toy
CBR600RR - Trackbike
bigup
PostPosted: 15:28 - 09 Feb 2010    Post subject: Reply with quote
neilb wrote:
It's a standard 12V 30A automotive 4 pin relay - I just asked for it in the local car parts shop.
I found it difficult to find the proper distribution block. You need one where the terminals on each side are linked together and not just a standard electrical terminal block. I ended up just bodging one of my own.
If anybody else has any ideas where to get a linked terminal block, can they let me know?
I got the diagram from this link:
https://www.canyonchasers.net/shop/generic/relay.php
It goes into a lot more detail on what you need and how to do it.
Good luck!!
hi mate., after googling i eventually found that site which looks pretty good,
you can get the block and jumpers on ebay: https://shop.ebay.co.uk/?_from=R40&_trksid=m38&_nkw=8+Position+Dual+Row
not cheap like but they are available!
think im gona try and give it a go.
supZ
PostPosted: 15:30 - 09 Feb 2010    Post subject: Reply with quote
ahhh thats exactly what i was after originally.. Mad
gl with it Smile
Dibble
PostPosted: 19:13 - 09 Feb 2010    Post subject: Reply with quote
Google a company called Vehicle Wiring Products if you want to save a bit on Halfords prices
PostPosted: 20:58 - 09 Feb 2010    Post subject: Reply with quote
Sounds like you want a marine busbar :-
https://www.power-store.com/view-item.asp?itemid=1230&id=200&
https://www.power-store.com/catalog/images/large/1230_4262.jpg
The last post was made 16 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 74.51 Kb
