nsr125 foxeye rear headlight unit catastrophy, please help.
sarge75
PostPosted: 19:48 - 09 Feb 2010    Post subject: nsr125 foxeye rear headlight unit catastrophy, please help. Reply with quote
I have just replaced my nsr125 foxeye rear headlight unit, unfortunately i didn't take note of the order of the 3 wires green,brown neutral for each light are supposed to go for each light. I have tried many combinations without success, before i cry can somebody please help,many thanks.
chip
PostPosted: 20:14 - 09 Feb 2010    Post subject: Reply with quote
theres some wireing diagrams if you havent already noticed them but it list 3 nsr125's so just gota work out which is your but i would assume all the lights would be wired the same
https://www2.bikechatforums.com/viewtopic.php?t=184540
alains
PostPosted: 11:42 - 10 Feb 2010    Post subject: Reply with quote
you have 2 sockets & 3 wires
the sockets work together in //
the 3 wires are : green (ground) , yellow/green (park lights) , brown (stop lights)
the ground goes to the outside of the socket , so begin by connecting it
then put 1 bulb , contact on with light switch in the middle , hold the yellow/geen wire and connect it to 1 terminal then see the light intensity , unplug it and connect it on the other terminal and compare with your previous . the yellow/green should be connected on the lower intensity , the brown on the other
afterwards you can put the second bulb and it should lite as the first
if your stop lights do not work check the switch adjustment on your break pedal
Mauy
PostPosted: 11:43 - 10 Feb 2010    Post subject: Reply with quote
i do it on my nsr 125 f '92 last night
yellow/green is the ground
green is the light
brown is the stop
I seem to remember so
if it not work tell me this evening I take a picture and post it tomorrow
Mauy
PostPosted: 11:45 - 10 Feb 2010    Post subject: Reply with quote
alains arrived before me
alains
PostPosted: 12:02 - 10 Feb 2010    Post subject: Reply with quote
mauy , keep in your mind : green is always the ground , red is always +12V before key , black is +12V after key
Mauy
PostPosted: 12:09 - 10 Feb 2010    Post subject: Reply with quote
tanks i hope i remember
have you got any idea for my engine problem????
alains
PostPosted: 12:11 - 10 Feb 2010    Post subject: Reply with quote
which one ?
explain , please
Mauy
PostPosted: 12:15 - 10 Feb 2010    Post subject: Reply with quote
i sent to you a pm yesterday an i opene a tread look in the workshop nsr 125 engine don't stop
The last post was made 16 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 57.92 Kb
