| badlydamaged |
 badlydamaged Spanner Monkey
 Posted: 19:42 - 30 Jun 2004 Post subject: 125 Top end on 100cc engine? |
Hey there,
I have a 1988 Kawasaki kH100 and have the oppotunity to purchase a KH125 Top end (piston, Barrel, Cylinder head etc). I was wondering could I swap the 100cc top end with the 125 one while still using the same carburettor, exhaust and bottom end? To me it seems possible, knowing that my friends RG has has a TS125 top end on (giving it 150cc).
From imformation I have found on the KH125 and KH100 engines the later 125cc engines(which is the engine type I am looking into) have the same stroke (and presumably the same crank shaft) as my KH100, so maybe my engine could be adapted to take the 125 top end and Piston?
Both 125cc and 100cc engines use the same side carburettors, are rotary disc valve strokers (with the same ignition timing) and both bikes use the same frame and have the same gearbox. The only thing I am concerned about is that the top end stud spacings may be different, meaning I couldn't bolt down the barrel onto the crankcase assembly, but obviously this would be impossible to tell until I started trying to fit it.
So does anyone think this is possible, or are the two engines likelly to be different in small ways so the top end isn't interchangable? It would interest me to find out .
Hope someone can help.
Cheers, Jonathan ____________________ My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts"
Add me to MSN if you want! badlydamaged@hotmail.com. |
| Robby |
 Robby Dirty Old Man
| badlydamaged |
 Posted: 20:26 - 30 Jun 2004 Post subject: |
Hey there, thanks for your comments
The Kh is a single, the 100cc was launched about 10 years before the 125 (although they both continued into the 90s) so I wouldn't think it is sleaved down unfortunatly, which was why I was wondering about the stud spacings, but like you say I think they could be the same.
However the whole bottom end seems identicle on both engines from the specs, even down to using the same clutch! But in pratice I wouldn't be suprised if there was some obscure and odd difference between the two.
I have actually got a slightly bigger carburettor off a GP125 waiting to go on the existing engine, the GP series and KH Series (including the tripples oddly enough) all used the same carbuerttor types as far as I can remember, just different bore sizes. I think I should be alright with a main jet size of 95 (original KH125 main jet size), as im not intending on doing anything stupid with the engine's state of tune.
Like you say, it should make an interesting project, and these parts are going to be cheap, so its worth a go!
Thanks again, Jonathan ____________________ My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
| badlydamaged |
 Posted: 11:27 - 02 Jul 2004 Post subject: |
Hey again, for anyone interested I have just spoken to my mechanic and he says that with these engines the 125cc top will go straight on without problems, he says the same is true of Suzuki's GP100 / 125 . If anyone is interested I will let you know if there are any probems when I get round to fitting .
The last post was made 21 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
