Rear sprocket wobble (ER5)
ncrn
PostPosted: 21:05 - 12 Feb 2010    Post subject: Rear sprocket wobble (ER5) Reply with quote
I've noticed the past couple of days that my bike sometimes (not very frequently) makes a sort of knocking/clunk sound as I launch, it comes from the left side of the bike and sounds like it comes from the rear wheel. When checking my chain last night I noticed I can wobble the rear sprocket side to side a couple of millimetres. What would cause this? And would this be making the odd clunk sound as I pull away? I half suspect my cush drive, but when I took the rear wheel off to fix the drum brake about 500 miles ago it didn't look too bad.
ncrn
PostPosted: 21:10 - 12 Feb 2010    Post subject: Reply with quote
Cush Rubbers are cheap. I'd start there.
Unlikely yours have been changed since 1997 Question
Pat
PostPosted: 21:30 - 12 Feb 2010    Post subject: Reply with quote
You can pack out worn cush drive rubbers with bits of wheelbarrow inner tube if you're too tight/skint to buy new ones.
Blue_SV650S
PostPosted: 21:50 - 12 Feb 2010    Post subject: Reply with quote
Side to side play is not the cush drive, it is the bearing ... sounds like your bearing is shot ....
That said, 'couple of mm' is hardly wort talking about is it?!!? Or do you mean CM?!?! Thinking
PostPosted: 21:59 - 12 Feb 2010    Post subject: Reply with quote
Hmm I took side to side to mean rotary play. If there's axial play in the bearing it needs changing.
Blue_SV650S
PostPosted: 22:10 - 12 Feb 2010    Post subject: Reply with quote
Hummmmmm .... yeah ... ....
ncrn, which sort of movement are we talking about here? Thinking
PostPosted: 22:21 - 12 Feb 2010    Post subject: Reply with quote
Not uncommon for the sprocket carrier bearing on those to collapse without any real fuss being caused.
My GPZ did it once, I don't know how long I was riding it like that for but it totally fubared the carrier casting. The bearing had almost turned to dust but because the wheel is sat on another two beaqrings, there wasn't much appreciable difference to the ride.
Probably best to check the bearing just in case. If it's ok, pack out the cush drive with slices of inner tube or wrap the segments with self-amalgamating tape while you're in there to tighten it all up.
Don't buy new rubbers, they will be just as loose again within a couple of months.
PostPosted: 22:43 - 12 Feb 2010    Post subject: Reply with quote
Agree with the bearing, but I would also consider that when you had the wheel off you put it back together without the spacer between the sprocket bearing and the wheel. This will kill the bearing pretty quickly, and about 500 miles isn't that far out.
ncrn
PostPosted: 23:00 - 12 Feb 2010    Post subject: Reply with quote
Its axle movement, and by the sounds of it I should take a look at the bearing then Laughing. Cheers guys, I'll have a look tomorrow and see.
ncrn
PostPosted: 13:20 - 13 Feb 2010    Post subject: Reply with quote
Well I've taken the wheel off and the sprocket carrier bearing is very slightly notchy and the left hand side rear wheel bearing is definitely notchy. The right hand side one is ok but I figure I'll change it as well.
The cush drive is fine, but I found the o-ring that sits around the wheel hub had split when I put the carrier on last time and was sat on the cush drive which probably attributed to the wobble I was seeing a lot.
Anyone got any good guides on how to replace wheel bearings?
PostPosted: 14:09 - 13 Feb 2010    Post subject: Reply with quote
No guides as such, but some tips:
1) Kawasakis have a big circlip holding the berarings in. Remove this first before hammering the shit out of it for ages and getting nowhere.
2) Buy a proper punch. You can do it with a bolt but a punch (with the facing filed square) is a lot easier.
3) They are totally standard size bearings. DO NOT buy them from a motorbike shop unless you want to pay five times what a bearing factors would charge. All three bearings are a different size on your bike.
4) If they are the original bearings, they are probably open ones with a seperate dust seal. Read the bearing number off the side of them and order ones using that number with "2RS" added to the end (denoting 2 rubber seals) these are sealed, pre-packed with grease and need no maintainance.
So, these are the bearing numbers for an ER5 (according to google). If you tell these to a bearing factor (yellow pages) they'll know what you mean.
Left: 6203 2RS Right: 6303 2RS Sprocket: 6205 2RS
After that it's down to cost. Generally speaking more expensive = better. FAG and SKF are two good makes I know.
So procedure:
Remove circlip.
Knock central 'tube' that goes between the bearings to one side exposing a slight lip on the inner race of a bearing.
Using a hammer and a drift against the inner race, tap the old bearing out, working round the bearing so it comes out square.
Lift out the tube.
Drift out the other bearing, you can use a socket set extension bar for this one, again butt against the inner race to remove it.
Make sure the bearing seats are clean and in good nick.
Drift in the first bearing until it is fully seated. Use something that is almost the same diameter as the outside of the bearing which butts against the outer race. Make sure you are absolutely square as it goes in. I usually use a big socket and extension bar for this job. You will be able to hear when the bearing is fully driven home.
Re-insert the tube and start tapping the second bearing in.
Once it's started, I usually locate the central tube by sliding a rolled up bit of cardboard through the middle of both bearings and the tube to hold it in place. I then drift the second bearing in until its inner race butts against the tube.
Replace the circlip.
Meshuggah
PostPosted: 17:40 - 13 Feb 2010    Post subject: Reply with quote
I had the same problem on my Fazer. Took it to the garage and they had to replace the sprocket and chain.
Problem solved.
It was something around 150 £ if I'm not wrong.
Shocked
ncrn
PostPosted: 18:20 - 13 Feb 2010    Post subject: Reply with quote
Cheers stinkwheel, I don't own a punch or a drift (not really sure what they are?) but will try to source them out before the bearings get here.
I re-fitted the wheel with a new o-ring and the wobble has massively reduced, all the same the bearings need swapping so will do that when they get here.
PostPosted: 20:36 - 13 Feb 2010    Post subject: Reply with quote
The o-ring is to keep out water & dirt and you can't rely on it for keeping the rotating assembly running true. Any notchiness in a bearing is bad news and a sign of impending failiure so you're doing the right thing by changing them all. You should check the manual by the way because many bikes specify one bearing be fitted before the other, so that the wheel is held in proper alignment.
PostPosted: 01:17 - 14 Feb 2010    Post subject: Reply with quote
Not essential to the task. You can just use a long bolt. I just find a proper drift is less prone to slipping off the edge of the race as you hammer it through. I couldn't find a good picture of what they look like (essentially a metal bar for hammering onto stuff with) so I took one. They are actually pretty usefull things to have around for driving things in/out, folding over the tabs on lock washers and suchlike.
With regard to fitting order. I'm pretty sure it's the same as on the GPZ where the right bearing is significantly larger than the left one. You fit the smaller one first through the hole the larger one goes in and it seats against a lip inside the hub.
ncrn
PostPosted: 02:10 - 14 Feb 2010    Post subject: Reply with quote
Yeah I completely agree, the issue appeared to stem from the fact that the o-ring was laying across the cush drive rather than in the hole it should live in (it had split in two). The wobble is still there just 70% of what it was. I fully intend to replace the bearings. I span the cush drive and the wheel on the axle when they were off the bike and I could feel the wear through the axle.
And to stink I spotted something similar when I was at a local tool shop earlier, so I think I'll pay them a visit again. I will take a look in my haynes before even attempting to get the bearings out, but I get the feeling you are right about the order from what I saw earlier.
There is a gap of 1 year, 239 days between these two posts...
finiteresourc...
PostPosted: 08:37 - 11 Oct 2011    Post subject: Same Issue: Cause: Sprocket Carrier Bearing Reply with quote
I had the same issue - see video here
The problem was the sprocket carrier bearing - 2mm play in the bearing. Got bearing & outer dust seal from Wemoto for £11.31 inc postage.
On the ER-500 A1, there's a shim that sits between the inner race and the axle - remove this carefully before tapping the bearing out. I just pushed the shim out by hand - comes out on the cush drive side - put it back into the new bearing the same way round that it came out.
Fitting was easier than expected, thanks to stinkwheel - I had the old bearing out and new one seated in the carrier in about 50 mins, ready to grease and reassemble.
Note: My ER-500 A1 did not have a circlip holding the bearing (or a recess for it to seat into, so I don't think it's just missing).
Service Manuals are available if you Google around.
Past: X7, Bros 400. Present: ER-5 (A1-98). Wishlist: 97 Speed Triple or Bros
orac
PostPosted: 22:48 - 11 Oct 2011    Post subject: Reply with quote
if you dont have anything other than a big hammer to fit the new bearing i would recomend using the old bearing as a drift. trying not to hit anything other than the outter race while keeping everything square is very hard. you should not use any other part of the bearing to puch it into place.
i got alot of noise from my carrier bearing the other day, it had no feelable play, just a tiny little bit of ruffness when turned. i new bearing, some use a of a large hammer later and the noise is gone.
also dunno if any of you guys have made a bearing fitting tool. some threaded bar, washers and nut for either end will allow you to draw them in correctly, again use the old bearings between the washers and new bearings
The last post was made 15 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 110.02 Kb
