Car Charger - can it be used
Shaheed
PostPosted: 10:43 - 01 Jul 2004    Post subject: Car Charger - can it be used Reply with quote
Hi All
Don't know much bout electricity, but know that my bike (NC30)wont start and the battery (which is 2.5 weeks old (?new)), is sounding like its dying a slow death.
I own a car charger, but it kicks out 4.5Amps per hour, and the references on the net say to trickle charge at less than 1 amp per hour (0.7 in fact).
One site reckoned that if you fit a 20-25W light bulb in serial to one of the terminals of the charger, it would lower the Amp rating going to the battery.
Does anyone know if this is true!??! Would the Amps drop if a lightbulb is connected in series? I dont want to blow/damage my new battery, but I wanna get to testing a fully charged battery with a multimeter!
Why wont this $*&%$# VFR start?!?
baldy
PostPosted: 10:50 - 01 Jul 2004    Post subject: Reply with quote
I use my car charger to charge my battery no problem. Just take the filler caps out (if it has any).
One day i will rule the world, just not today.
tatters
Exxon Valdez
PostPosted: 10:52 - 01 Jul 2004    Post subject: Reply with quote
its ok to charge a bike battery with a car charger, all that is bollocks and does,nt really matter l,m a electrical engineer and should know better but l,ve always used a car charger on bike batterys, just don,t leave it charging for too long, just till the charger dial drops to were battrey is taking little/no more charge
tatters
Exxon Valdez
PostPosted: 10:54 - 01 Jul 2004    Post subject: Reply with quote
no need for that all non-sealed battreys have a vent on the side
Shaheed
PostPosted: 11:20 - 01 Jul 2004    Post subject: Reply with quote
Thanks for all the info!
If I do the calcs, then a fast charge should be for about 40mins!?
and a full charge should be about 2 hours.
What is the time that it should generally be left on for, given that the battery aH=8 and the charger is proving 4.5 amps? Can it be left on for longer than the 2 hours, without it damaging the battery?
Frost
PostPosted: 11:39 - 01 Jul 2004    Post subject: Reply with quote
just listen to the battery. fizzing = good, bubbling = bad Wink
mchaggis
PostPosted: 18:04 - 01 Jul 2004    Post subject: Reply with quote
If you're wanting to lower the current flowing to the battery, you want to connect a bulb or something in parallel. I used a car trickle charger on mine without any trouble.
PostPosted: 19:23 - 01 Jul 2004    Post subject: Reply with quote
I would say you can use a car charger, but possibly not on some newer style sealed batteries (not sure what battery your bike uses).
A car charger finished off the sealed battery for my 1200 Bandit.
Shaheed
PostPosted: 15:07 - 02 Jul 2004    Post subject: Reply with quote
It is a sealed battery (YTX9-BS Yuasa, I think).
To MCHAGGIS - As far as I remember my basic physics, I think connecting anything in parallel will not change anything in the circuit (think old v new christmas lights).
Series may be possible (but I am not sure), hence I need these opinions.
Another interesting take on the Reg/Rec saga. An autoelec told me that they mainly blew because people fitted headlight bulbs of greater than 35W. Anyone know anything about this one? (why would you fit bulbs other than standard - and if you did, you would make sure the current draw was within range...surely?!?) Will have to check my lightbulbs, just in case...
Frost
PostPosted: 15:46 - 02 Jul 2004    Post subject: Reply with quote
Parallel will split the current. if you connect up two bulbs in parallel and supply only enough power to light one, both will light at half brightness. as one effectively short circuts the other one.
if you were to conenct then in series the light bulb would act like a resistor/fuse and would either step down the power slightly, or blow.
Zx6man
PostPosted: 15:51 - 02 Jul 2004    Post subject: Reply with quote
you can go get a small bike batt charger for less than a tenner, why risk damaging a battery??
mr jamez
PostPosted: 18:09 - 02 Jul 2004    Post subject: Reply with quote
Oh where from? Smile
I have been looking around localy but cannot find one Doh!
PostPosted: 19:38 - 02 Jul 2004    Post subject: Reply with quote
People fit larger capacity bulbs so that they can see more at night.
The NC30 charging system is quite marginal. The manual lists it as up to 6 amps at 5000rpm, which at 15.5v is only 93 watts. With 2 60/55 watt headlight bulbs (UK spec version) at 5000rpm you are draining the battery and putting the regulator / rectifier under maximun stress.
For comparison an early CBR600 is listed as 315w output at 5000rpm.
UK spec battery was a YTX7A-BS.
Zx6man
PostPosted: 10:01 - 05 Jul 2004    Post subject: Reply with quote
Mand P do one for 15 quid, still better than taking the risk. You do really need an optimate, I have one for each bike and are very good, although about 35 notes each.
Shaheed
PostPosted: 09:46 - 06 Jul 2004    Post subject: Reply with quote
So lets think about this........in your car or bike, all the bulbs are in parrallel (i.e. if one blows, they all dont blow). So if all the lights blew, except one indicator bulb, you'r implying that all the current will be multiplied/stacked up and be forced through the indicator??! (including the current that usually powers a headlight). Rolling Eyes
Parallel does "split" the current, but it does not HALVE the current. It directs the same amount of current down both cables, and can power the same size bulb off both cables.
Thanks for trying to help tho!
The last post was made 22 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 87.05 Kb
