Excel Help
smegballs
PostPosted: 15:21 - 17 Feb 2010    Post subject: Excel Help Reply with quote
I'm having trouble with making a letter generator in Excel.
https://i46.tinypic.com/652vex.jpg
That is the format of how I want it to read. When F9 is pressed (recalc) the letters will be randomly generated from A-Z within the bottom row. I have got this far using random number generator, conditioning the random number and using a VLOOKUP table to return a letter value.
However in my application there can only be one of each letter per row otherwise it won't work. With a simple random number there is nothing to stop the same letter being generated twice within the row. Is there an "easy" way to make a unique letter for each position or is this heading into proper algorithm territory?
Karma if you know what it is! Laughing
Some people WILL have seen this or something very similar before
FreshAL
Sir Crashalot
PostPosted: 16:37 - 17 Feb 2010    Post subject: Reply with quote
3 columns: A B C D E
in A place 1 to in decreasing numerical order
in B place letters a-z, in alphabetical order starting with 'a' in cell B1
in C1 place "=rand()" can copy this down to C26
in D1 place "=RANK(C1,$C$1:$C$26)" and copy down to D26
in E1 place "=VLOOKUP(D1,$A$1:$B$26,2)" and copy down to E26
F9 now gives your index number in column A and your randomly sorted letter in column E
smegballs
PostPosted: 17:03 - 17 Feb 2010    Post subject: Reply with quote
Nice one, I'm having a play now so will give this a go!
EDIT: Works a treat! What also good is I can see how its working! Haven't used excel in a while so I'm rusty.
I don't suppose you know quite how "random" the random number function is? I've heard that apparently some are not that random due to the way a computer works.
Charlie
PostPosted: 17:40 - 17 Feb 2010    Post subject: Reply with quote
How random do you want it? A computer program will never be truly random, unless it looks thermal noise from some electronic component.
I may have remembered the bit thermal noise wrong, it was mentioned in a lecture in passing and I was tired
smegballs
PostPosted: 17:52 - 17 Feb 2010    Post subject: Reply with quote
I just had a google and it seems most "random" numbers are made by psuedorandom generators.
I'm working on an encryption matrix *Big hint for the guessy game* so the more random the better, but I doubt it will be attacked with mega hardware so computer random should be fine for the moment.
Alexio
PostPosted: 18:02 - 17 Feb 2010    Post subject: Reply with quote
Computers can get pretty damn close to random if you ask me. If you give the random number algorithm a seed based on enough variable information you're good to go. That's why something simple like the current time in microseconds passed since the last actual second is given, or this with a unix timestamp as a salt etc. Something like an analogue measurement of a computer component (current fan RPM and CPU temp?) or whatever thrown in to the mix will make it all the better Thumbs Up
Charlie
PostPosted: 18:13 - 17 Feb 2010    Post subject: Reply with quote
Not sure how Excel generates it, however a lot of programs use unix time as the starting point for the random number. So if you know the exact time a random number is created and what was used to create it, it could be possible to figure it out.
Like I say I am definitely sure how much of the stuff I am telling you is correct!
Edit:
I was still posting while the last reply was submitted. Never mind.
smegballs
PostPosted: 18:30 - 17 Feb 2010    Post subject: Reply with quote
Well its all working nicely now, a big matrix with no repetitions or other unwanteds.
Thanks again AL.
The last post was made 16 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.49 - MySQL Queries: 15 - Page Size: 57.1 Kb
