| Ditto |
 Ditto Nearly there...
| spiderwheels |
 spiderwheels Two Stroke Sniffer
 Posted: 16:58 - 20 Feb 2010 Post subject: |
It sounds like running out of petrol. You can try unscrewing the drains on the carbs and check fuel flows out.  |
| Ditto |
| spiderwheels |
| Ditto |
| Ditto |
 Posted: 18:30 - 20 Feb 2010 Post subject: |
Just had a look in the tank, and although the petrol seems ok, the level seems to be below some sort of nozzle sticking up. Im thinking it might be on reserve and may be a problem here?
Cue paint diagram:
https://img32.imageshack.us/img32/7166/tankpoblem.jpg ____________________ CG 125 > Bandit 600 > CBR 600 FY > Street Triple R |
| Kickstart |
 Kickstart The Oracle
| spiderwheels |
| Ditto |
| Kickstart |
| Ditto |
| Kickstart |
 Posted: 19:24 - 20 Feb 2010 Post subject: |
That would just dry the plugs, and they would be drenched again rapidly if you restarted the engine. You could probably take them out and give them a clean (burn the fuel off them with a blow torch).
Most likely causes of flooding would be a float height set incorrectly, float punctured, worn needle valve or a dirty needle valve. To check any of these properly means taking the carbs off (which is a pain on the Bandit, if you unbolt the airbox and slide it back there is only just enough clearance to get the carbs out). However if it is just dirt in the needle valve (probably the most likely thing to suddenly occur) then sometimes you can fix it by tapping the carb float bowl (use the handle of a screw driver).
Just don't leave the petrol on prime. Or you might land up with the 3/4 of the contents of the petrol tank draining through the carbs into the airbox and engine overnight .
| Ditto |
 Posted: 18:39 - 21 Feb 2010 Post subject: |
Right so today i had a good look, took tank off etc. All the pipes seem fine, and i even filled the tank back up with a jerry can up above the main tank pipe.
Still no luck though. Really am confused. It just didnt want to start.
So i took off the fuel tap completley and there was some sediment in the reserve pipe. I assume this is what might have caused the problem but the bike still didnt start when the tank was filled back up, not using the reserve pipe.
Spark plugs also seem fine.
Really stuck with what to do now
Cheers ____________________ CG 125 > Bandit 600 > CBR 600 FY > Street Triple R |
| spiderwheels |
| Ditto |
 Posted: 19:48 - 21 Feb 2010 Post subject: |
Alright ill give that a go tomorrow, cheers.
Nope, no filter. The haynes manual says there should be one, but i guess that might be on the newer models, or the fuel pipe changed at some point.
If there was sediment, would this have gotten into all the carbs? Or just 1 or 2?
So hold the pipe like this and check the level?
https://img96.imageshack.us/img96/9639/carbprobelme.jpg
| spiderwheels |
 Posted: 12:36 - 22 Feb 2010 Post subject: |
Nice diagram
Seeing as you've got the Haynes the whole procedure for checking the fuel level should be in there - although millimetre accuracy in the fuel level isn't necessary to get it to start!
You'll have to check all 4 carbs. If it turns out that none of them are flooding the sediment has probably got through to the jets.
If you have to strip the carbs you will want to make sure you've got some sort of fuel filter in place before you connect your fuel tank back up - you will have to use the prime position on the fuel tap which probably feeds from the reserve where all the dirt is. |
| Ditto |
| Kickstart |
| Ditto |
| Kickstart |
| temeluchus |
| Ditto |
| temeluchus |
| temeluchus |
| Ditto |
 Posted: 16:30 - 22 Feb 2010 Post subject: |
Cheers for the video.
So i should expect to take the float bowl off, and find sediment from the fuel tank in the 'Needle Valve Assay', number 11 on this diagram?
https://img713.imageshack.us/img713/4316/carbdiagram.jpg
I owe you all a beer if this fixes it
The last post was made 15 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
