Thermal Imaging?
and
PostPosted: 20:39 - 21 Feb 2010    Post subject: Thermal Imaging? Reply with quote
Im-a-Ridah
PostPosted: 21:39 - 21 Feb 2010    Post subject: Reply with quote
Yea should work fine, military use them on tanks, IFVs ect Smile
WishayKillie
PostPosted: 22:55 - 21 Feb 2010    Post subject: Reply with quote
We use them for maintenance on the switchboards to check for loose connections etc
https://i62.photobucket.com/albums/h99/WishayKillie/work/IR_0038.jpg
https://i62.photobucket.com/albums/h99/WishayKillie/work/IR_0040.jpg
Dagon
PostPosted: 14:51 - 22 Feb 2010    Post subject: Reply with quote
I'm nitpicking but that's not thermal imaging it's an Infrared camera. Both use infra red but they use it in different ways.
WishayKillie
PostPosted: 15:51 - 22 Feb 2010    Post subject: Reply with quote
Cool Thumbs Up
But whats the main difference then? I just though that the terms "Infrared" and "Thermal" imaging were interchangeable Neutral
Dagon
PostPosted: 18:56 - 22 Feb 2010    Post subject: Reply with quote
Sorry I should clarify that. You're right that they're all thermal imaging systems in that they use thermal emissions and then display an image on a screen
You'll find though the term 'thermal imager' is usually used for the devices used by the military and police (also called FLIR).
They work quite differently to the camera you'd be using for your maintenance. A thermal imager isn't designed to tell you the temperature of something. It's designed to give you a image you can see things and navigate by.
It varys by device but the ones I've used worked by cooling themselves to about -100 internally. They use this a a reference point when checking the temperature of everything thing around and then build a clear image. The cooling is one reason why they are so bulky and expensive.
The cameras you're using don't use any sort of baseline, they just throw a colour on the screen for the strength of the infra red they see. They also tend to have a much shorter range and basically aren't designed to give you an image you can see by - just tell you the temperature of whatever they're pointed at.
iooi
PostPosted: 19:15 - 22 Feb 2010    Post subject: Reply with quote
Just got to remember that it will not pick up stuff like dead animals, pot holes, piles of shit/gravel or other road surface dangers.
All of which are a greater danger to bikers than a person walking or a car parked at the side of the road.
Fact is even driving a car or bike with it installed in bad weather or darkness still won't stop that idiot pulling out of a junction or turning across you.
At the end of the day driving at a speed, so you are unable to stop in the distance you can see in, is reckless.
This is just another device that is fooling drivers into driving faster than they can safely manage.
The last post was made 16 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 15 - Page Size: 53.5 Kb
