Mikes Brakes
PostPosted: 22:55 - 01 Jul 2004    Post subject: Mikes Brakes Reply with quote
Mike came round tonight so that we could bleed his brakes. Had a quick session with them, then decided to clean the calipers up a bit. At this point we found this brake connector:-
https://www.alfa-pages.co.uk/TempPicture/mikesBrakes.jpg
Guess who isn't riding home tonight.
Lesson for today - don't touch alloy connectors on braided steel hoses.
McJamweasel
BCF Junkie
PostPosted: 22:58 - 01 Jul 2004    Post subject: Reply with quote
Holy shit! Shocked
PostPosted: 23:01 - 01 Jul 2004    Post subject: Reply with quote
Race fittings... anodised...
Shocked
Lucky man... Smile
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Sparks!
Sir Tart-a-lot
PostPosted: 23:02 - 01 Jul 2004    Post subject: Reply with quote
He don't have much luck with brakes and stuff does he (or was the split line Col.? and wasn't it mike with the fooked car wheel?) Laughing
McJamweasel
BCF Junkie
PostPosted: 23:04 - 01 Jul 2004    Post subject: Reply with quote
The split line was me, the fooked tyre was him.
Robby
Dirty Old Man
PostPosted: 23:06 - 01 Jul 2004    Post subject: Reply with quote
What is it with north and brakes.
jayluvmito
PostPosted: 23:15 - 01 Jul 2004    Post subject: Reply with quote
aluminium fittings tend to have a habit of splitting hence being sold as 'race use only'
one day...
WildGoose
White Van Man
PostPosted: 23:19 - 01 Jul 2004    Post subject: Reply with quote
nothing to me with me Rolling Eyes
although that might explain the fade they used to have Confused
it was pointed out from the garage, that altho he didnt fail the MOT because of them, he would advise me to change them
Mr C
PostPosted: 23:20 - 01 Jul 2004    Post subject: Reply with quote
I guess it's different metal corrosion between teh steel and aluminium
a bit of electrolyte in there (salt water) and off you go - rotting away underneath you
they're ok for race use because if they get wet they will be changed and if they don't they'll probably be changed anyway
mine are all stainless steel on Hel lines
187.3bhp = 201mph
PostPosted: 23:33 - 01 Jul 2004    Post subject: Reply with quote
I mentioned them to Mike some time ago. Lucky he came round to bleed the brakes and so this was noticed. We were wondering who fitted the hoses, so if not Goose then presumably Box Hill Motorcycles.
Think the main problem with the alloy fittings is that as they are tightened up it is inevitable that some of the anodising is scratched off, so allowing corrosion to start on the unprotected alloy.
By the way, the other caliper was almost seized onto the pins it slides on. The brakes now have very little travel and work well. Pity we will have to bleed them again tomorrow.
WildGoose
White Van Man
PostPosted: 23:45 - 01 Jul 2004    Post subject: Reply with quote
they were on the bike from purchase, i would be surprised if box hill did it to be honest, unless the rubber hoses were really bad
in which case they may have been installed in early 90's whenever the bike was first used, then may have been sat in a crate on a dock (as the typical grey import saga goes according to magazines) to corrode away
who knows, a bit slack on my part, but the brakes were always good enough
PostPosted: 00:09 - 02 Jul 2004    Post subject: Reply with quote
Suspect that they were UK sourced and not Japanese sourced. Not heard of a Japanese import coming into the UK with braided hoses already (not sure they are legal at all in Japan, those ones would certainly be illegal in many countries).
Claud 14.7 to 1
PostPosted: 07:42 - 02 Jul 2004    Post subject: Reply with quote
Hang one, is the line steel, not stainless steel?
Why exactly is it corroding? Sorry im stupid today...
So stainless steel hoses would not give you this problem then?
Mr C
PostPosted: 09:09 - 02 Jul 2004    Post subject: Reply with quote
now I'm sure someone will come along with a far better explanation that I can possibly come up with given that my metallurgy is at least 12 years old
every metal has a kind of electrical potential, and they are all different
... scratch that - here's an explanation of galvanic corrosion from a good googling
Galvanic corrosion tends to occur when dissimilar conducting materials are connected electrically and exposed to an electrolyte. The following fundamental requirements therefore have to be met for galvanic corrosion:
Dissimilar metals (or other conductors, such a graphite).
Electrical contact between the dissimilar conducting materials
(can be direct contact or a secondary connection such as a common grounding path).
Electrolyte (the corrosive medium) in contact with the dissimilar conducting materials.
When placed in an electrolyte, different metals/alloys assume different corrosion potentials (refer to the galvanic series in seawater). It is this potential difference that is the driving force for galvanic current flow. The less noble material in the galvanic couple will become the anode and tend to undergo accelerated corrosion, while the more noble material (acting as a cathode) will tend to experience reduced corrosion effects. However, in some cases, chemical species produced at the cathode can degrade certain cathode materials.
basically a current flow is set up (electrons moving from one metal to the other) which results in the degradation of one of the metals.. this is pretty much how batteries work
it wouldn't matter if the line was stainless or not as the connector is ally and would have a similar galvanic potential difference to either steel or stainless steel - the result would be the same
I dare say a stainless steel hose with an ally connector would suffer accelerated corrosion, actually making it worse as I think Chromium is further away from Aluminium on the galvanic scale - although I couldn't swear to that (the main difference between mild steel and stainless steel is the addition of chromium inclusions)
the key to avoiding this in engineering terms is to make sure that wherever you have metals in contact, you should try and make sure that they are not too dissimilar in terms of galvanic potential, obviuosly steel and aluminium are a fair way apart (as an example, zinc and carbon are 1.5 volts apart, this is why zinc carbon batteries are 1.5 volts as a single cell)
in summary
keep yer tarty aluminium brake bits - they are dangerous, they rot and they aren't as strong as steel in the first place, but hey I'm sure you'll feel the benefit of the 0.1 grams saved in weight Rolling Eyes
make sure your banjo and other connectors are stainless or at least steel you know it makes sense Wink
187.3bhp = 201mph
Zx6man
PostPosted: 09:39 - 02 Jul 2004    Post subject: Reply with quote
when in all weathers on my old zzr600, the brakes were stripped every week to keep em in good nick, I used to do them while waiting for the missus to get ready for work. A lot of folk tend not to check their bikes over if nothing seems wrong.
Claud 14.7 to 1
PostPosted: 10:51 - 02 Jul 2004    Post subject: Reply with quote
Ok i see, so the salt water would be acting as the electrolyte. The addition of electricity, in this case is not required. The difference in the metals would be enough to cause the corrosion (with the addition of salt water soultion)...
The key is to keep metals that are in contact, identical in material. TBH i would have thought that all the parts used would have been stainless steel anyway, obviously not.
Interesting and helpful, thanks Mr. C! Thumbs Up
I vaguely remember this stuff from GCSE chemistry...
Mr C
PostPosted: 11:43 - 02 Jul 2004    Post subject: Reply with quote
yes you see, the stuff they teach you at school does often have a real world application
187.3bhp = 201mph
Mr C
PostPosted: 11:44 - 02 Jul 2004    Post subject: Reply with quote
and having thought about this, I have just been out and fitted the rear Hel line that has been sat in my garage for aeons
probably be sliding around with the rear all locked up now as the OE one was shite
187.3bhp = 201mph
PostPosted: 13:16 - 02 Jul 2004    Post subject: Reply with quote
It is a far better idea to use stainless steel fittings, or at least steel ones.
The last post was made 21 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 105.11 Kb
