Failed bike modifications
MarkJ
PostPosted: 13:58 - 24 Feb 2010    Post subject: Failed bike modifications Reply with quote
I always seem to come up with these bright ideas, but sometimes they don't always go as planned. Is it just me? Post your failed modifications Laughing
Arrow Stebel Nautilus - I couldn't find anywhere to fit the first Nautilus I bought so put it behind the numberplate. All went well untill I went over a big dip in the road which squashed the suspension low enough for the rear wheel to rip the horn off, punch a hole in my undertray and pull my rear hugger off Rolling Eyes It must have cost me a good £40 for another nautilus and spray paint for the hugger
Arrow HID headlights. These would have been OK if I didn't need the bi-xenon H4 kind. I ended up with some that had the shield screwed on and the "full beam" were some small bulbs attached to the side of the HID filament that were as bright as sidelights. These bulbs also gave a shocking beam pattern and I'm back with normal filament bulbs
Arrow Bar muffs. Did my head in everytime they'd push on the levers at speed.
Arrow For this winter I bought some coloured reflectors for the front, side and back of my bike in an attempt to be noticed a bit more. Has made no difference at all Thumbs Down
Doovy
PostPosted: 14:05 - 24 Feb 2010    Post subject: Reply with quote
- motrax twin horns.
they just looked stupid wherever they were on my naked hornet.
- mesh on my bellpan.
it looked like a fishing net full of scum after a few weeks of winter riding.
PostPosted: 14:08 - 24 Feb 2010    Post subject: Reply with quote
I couldn't find anywhere to fit them on my scooter so gave them to my dad.
PostPosted: 14:11 - 24 Feb 2010    Post subject: Re: Failed bike modifications Reply with quote
You can get stebul naultius for £20 new on the bay
Poke a hole in the muff where the barend is the sscrew the barend through the muff this will hold it in place.
Try this, it worked for me
https://www.bikechatforums.com/viewtopic.php?t=191601
I never fitted anything to my bike that failed, I have a few bits I never put on because they would have probably failed.
The only thing I can think off is stick on knee sliders, fell over after about 100miles
Bishbash
PostPosted: 16:04 - 24 Feb 2010    Post subject: Reply with quote
Only thing I can think of was when I put flush indicators on my R1, they were so flush you couldn't see them at all. Rendered pointless
Im-a-Ridah
PostPosted: 16:25 - 24 Feb 2010    Post subject: Reply with quote
Depends what you want the HID for. If its for the extra light, then just fit H1 or H3 HIDs in some aux lights Smile
My biggest issue with motorcycle lighting though isn't such much how much light, but rather that it aims the wrong way in corners!
MarkJ
PostPosted: 16:53 - 24 Feb 2010    Post subject: Reply with quote
@ Chris, I did get another Nautilus off ebay for £20, but spent another £20 on the paint for the hugger which was broken. I have done the hole in the muff (Laughing) trick with them, but the front would just collapse backwards and downwards - there was no support in them, probably because they were £10 off ebay.
@ Chris & Rydah, I am going to get a proper projector headlight and have a proper go at HIDs & LED sidelights when I get a bit more money saved up. I have the common-as-muck dominator headlights at the moment which are pretty poor.
PostPosted: 19:42 - 24 Feb 2010    Post subject: Re: Failed bike modifications Reply with quote
On the bar muffs - you need to at least fasten these on to the barends. Alternatively, stick some enduro hand guards on and use them to put the muffs around - I actually made my own guard out of some old shelving for the zx9 and it seemed to work well.
Edit.... also going to mention extra side lights, but seems I've been beaten to it Smile.
Plan is to stick 'neon string' all over the outside of the GSXR in appropriate colours (white front/amber side/red rear), but want some cheapo chinese fairings first and it's probably going to be summer before I can afford them Sad.
At least I've made use of the neonz in the mean time Very Happy ...
(Oh and I also did the HID - but did my research first and got one that moved rather than with an extra bulb Smile, haven't fitted my stebel yet, waiting for the fairings as I may cut them up a bit to have it front-facing etc.
superchick
PostPosted: 19:42 - 24 Feb 2010    Post subject: Reply with quote
my bike has some go faster scratches
PostPosted: 19:46 - 24 Feb 2010    Post subject: Reply with quote
Best styling mod - suggests to other riders you've 'tried' at some point Razz.
superchick
PostPosted: 19:47 - 24 Feb 2010    Post subject: Reply with quote
you mean when i was cornering at 200mph kneedowning and picking flowers from the verge?
MarkJ
PostPosted: 20:36 - 24 Feb 2010    Post subject: Re: Failed bike modifications Reply with quote
The ones I bought were advertised as bi-xenon and every other bi-xenon kit I'd seen had used the solenoid on the shield. I obviously didn't look hard enough! One of the reflectors on the dominators is wrong anyway - doesn't throw a proper dipped pattern. Also the wiring is a right bodge job - whoever put these dominators on just used crappy bullet connectors and it desperately needs re-doing. The common ground for dipped/full gets really hot after they've been on, and both the HID bulbs wouldn't ignite without revving the bike anyway. It's a perfect excuse to make my own single projector headlight with a switchable shield, and rewire it to use a relay Very Happy Also, I didn't get on with the 6000k colour, I hated the blue tinge at night. I can re-use the slim ballasts and just buy some 4300k bulbs
I did eventualy use a coathanger as a frame for the muffs anyway. Don't need muffs anymore because I never get to go fast enough for it to cool my hands that much
GSF Jamie 600
PostPosted: 23:41 - 24 Feb 2010    Post subject: Reply with quote
Its the worst feeling grrr
* bellypan for my naked bandit doesnt fit
* snapped one of my mini indicators when putting on
* snapped a bolt when installing my renthals
* exhaust (sounds good) but makes a tinny noise at 3k =(
Dazbo666
PostPosted: 00:04 - 25 Feb 2010    Post subject: Reply with quote
Tried a DIY mesh mod for the fairing infills on my old GPZ. (I got the idea from a boy-racer / rally car mod with mesh panels in the body kit)
All I can say is that the mesh was never used while the bike was on the road, mainly because of my poor DIY skills and insufficient tools.
I also had a Stebel Nautilus horn fitted on the GPZ. I took it off the GPZ to fit it to the Bandit, but can't find any suitable space to fit it properly, so now it's surplus until I can find a suitable position and/or make a custom DIY bracket
I'm only hoping that my DIY skills are steadily improving because I find that my modding plans are often more ambitious than my abilities Rolling Eyes LOL
Word of the day : DILLIGAF
Phoenix
Twisted Firestarter
PostPosted: 00:34 - 25 Feb 2010    Post subject: Reply with quote
I don't know whether it's possible on your bike but I positioned my Stebel Nautilus under the tank and behind the carbs in the big empty space there (old Fireblade), fits perfectly and not really much heat there, it's a full size car Nautilus too not the bike one.
Only mods that has failed really is the heated grips I got free seemed to suffer a fault switch module presumably due to water penetration on day one of fitting them, now need to remove the fuse otherwise they come on and off randomly.
I also fitted some Angel Eyes into the headlights to use as a low power sidelight for day riding instead of dipped beam. They look good I think but started to come loose when the glue I used to fit them melted from the headlight bulbs when they're on, I checked the melting point and it was sufficient but clearly the IR heat is too intense. Need to dismantle the headlight unit again and refit them somehow, have a plan though.
PostPosted: 00:42 - 25 Feb 2010    Post subject: Reply with quote
Only because you tightened the bolt when you were trying to loosen it Laughing
Lefty Loosey. Righty Tighty Wink
Dazbo666
PostPosted: 00:46 - 25 Feb 2010    Post subject: Reply with quote
Phoenix wrote:
I don't know whether it's possible on your bike but I positioned my Stebel Nautilus under the tank and behind the carbs in the big empty space there (old Fireblade), fits perfectly and not really much heat there, it's a full size car Nautilus too not the bike one....
I haven't had the Bandit long, and certainly haven't had the tank off it yet, so I'm still not sure how much space is under there.
However your suggestion sounds like the beginnings of a plan for me Thumbs Up
Visitor Q
$25 whore
PostPosted: 14:02 - 25 Feb 2010    Post subject: Reply with quote
Bar ends. Go through the fuckers at a rate. CBR has weird internals Crying or Very sad All other bikes have been fine. Now they're just cobbled on in a hodgepodge fashion and I don't care.
Gave up trying to fit a scottoiler.
PostPosted: 14:25 - 25 Feb 2010    Post subject: Reply with quote
Note that with the little stebel, I believe you can separate the compressor and the horn - my thought was to stick the compressor under the rear seat on the GSXR and run a hose to the front for the horn.
Deckx
PostPosted: 14:36 - 25 Feb 2010    Post subject: Reply with quote
Digital Gear indicator... what a waste of time / effort installing it and trying to calibrate it.
Cheap crash bungs... bought some cheapies from Taiwan, shit plastic and too small, ended up binning them and ordering another set of R&Gs.
Magnetic Sump Plug...DO NOT BUY THESE.. Bolt was too short and i suspect the thread was slightly different (looser). Ended up damaging threads on the sump after a couple of oil changes. Put back in the original but it still drips. Something I can live with at the moment but will probably get worst every oil-change Neutral
PostPosted: 18:48 - 26 Feb 2010    Post subject: Reply with quote
You'll have to do what Nathanthepostman does off ADVrider:
https://photos-g.ak.fbcdn.net/hphotos-ak-snc1/hs208.snc1/7529_193826764687_509264687_4025184_2407804_n.jpg
He had to glue his sump plug in Laughing
Clanger
Stirrer
PostPosted: 18:55 - 26 Feb 2010    Post subject: Reply with quote
Raptor fairing: looks good but is shoddy at night. So I took that one off quick smart.
Tiny arrow indicators: they are possibly the hardest bulbs to change when blown. Have since exchanged for Bandit 400 standard indies.
The last post was made 16 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.30 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 124.61 Kb
