| Supersport |
 Supersport Derestricted Danger
 Posted: 09:58 - 02 Jul 2004 Post subject: NS125R won't go - any ideas? |
My son got an NS125R for his 17th birthday a fortnight ago. Yesterday I got a call for help - it had broken down with him. The bike had previously been starting easily and running well. He rolled up to a junction and it had stopped and wouldn't start again. When I got it home and checked it out there were sparks, plenty of petrol, it has compression and the inlet sucks when it is turned over. I tried replacing the plug - no difference. I took the carb off and checked it for dirt/water in the jets - nothing there. I checked the reeds were intact - they were fine. When kicking it over it doesn't fire at all but every 7 or 8 kicks it gives a "Phut" out the exhaust, so it is pumping mixture through and igniting it in the exhaust. This suggests to me that the ignition timing is way out, yet the pickup is firmly attached and the flywheel hasn't slipped on the shaft. Can CDI units fail in this way where the appear to produce adequate sparks but at the wrong time? Any help will be gratefully received, I have a 17 year old new biker who is pretty glum at the moment.  |
| badlydamaged |
 badlydamaged Spanner Monkey
 Posted: 11:33 - 02 Jul 2004 Post subject: |
Does sound like the timing is out, this happened to my bike after the previous owner assembled the engine without a thrust washer, allowing the crankshaft to move back and forth when the clutch / gear lever was operated and in turn allowing the timing to slip. I would think it was unlikely this is your problem (It wouldn't have lasted so long before going out of time I dont think) but I thought I would mention it just incase.
I dont know much about CDI igniton systems, but I guess it could very well be possbile that the CDI has packed up, after all dont they control the automatic advance / retard of the spark under different running conditions? By the way, according to Parts Partners your ignition timing should be: 19 deg idle,10 deg @ 10000rpm. Also the correct spark plugs for your bike are BR7ES with a gap of 0.7mm, just in case.
Good luck with with it
Cheers, Jonathan ____________________ My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts"
Add me to MSN if you want! [email protected]. |
| mr jamez |
 mr jamez World Chat Champion
| Supersport |
| Robby |
 Robby Dirty Old Man
| Kickstart |
 Kickstart The Oracle
 Posted: 19:52 - 02 Jul 2004 Post subject: |
Compression should be 156psi, give or take 43psi.
The spark plug should be a BR6ES, DR7ES or a BR8ES.
If it is sparking then the kill switch is probably fine.
Ignition coil primary resistance = 0.16~0.2 ohms. Secondary resistance (with plug cap) 7.35~10.85 k ohms, 3.6~4.6 k ohms without the plug cap. Pulse generator coil resistance = 50~180 ohms. Pulse generator air gap = 0.9mm. Exciter coil resistance = 50~200 ohms.
I would go with the ignition timing being out, possibly due to the flywheel moving slightly. This can happen when the woodruff key that locates it onto the crank shears off.
| theshmoo |
 theshmoo Bottomless Pit
| Jammy-G |
 Jammy-G Banned
| Supersport |
The last post was made 22 years, 111 days ago. Instead of replying here, would creating a new thread be more useful? |
