PDF - print problem for drawings
Deckx
PostPosted: 15:35 - 26 Feb 2010    Post subject: PDF - print problem for drawings Reply with quote
Hi,
I have certain PDF drawings (converted from CAD) which look ok when I open them on the computer screen but when I go to print them there are covered in random lines..(I'm using Adobe Acrobat 6 Pro)
I tried printing on another computer and they come out ok ? Tried everything like hiding sigs, stamps etc
Any ideas ?? cheers
Clanger
Stirrer
PostPosted: 15:40 - 26 Feb 2010    Post subject: Reply with quote
I know it sounds corny, but have you shut down your pc completely and rebooted and tried again? If yes, and it is still doing it; reload Acrobat (sounds like a bug). Cool
Handsome
PostPosted: 15:46 - 26 Feb 2010    Post subject: Re: PDF - print problem for drawings Reply with quote
Lines of what, colour or text ?...
Random coloured lines might mean you need to clean the printer seeing as they come out ok on others, you can buy sheets that clean it out as it goes through the printer and cleans the rollers and printing surfaces...
Lines of text I'd have no idea on...
yen_powell
PostPosted: 16:30 - 26 Feb 2010    Post subject: Reply with quote
Are you making the PDFs directly in AutoCAD?
XT1200Z and a DR350 in bits
Deckx
PostPosted: 17:32 - 26 Feb 2010    Post subject: Reply with quote
The Drawings have been converted from CAD,
The lines are like they have been left over from whoever CAD'ed the original drawings ie they go diagonally from one point to another like tracks of a mouse pointer Question
Weird... I even tried re-printing them again to PDF printer, look fine until I actually try and print them in paper and same problem ??
Clanger
Stirrer
PostPosted: 17:49 - 26 Feb 2010    Post subject: Reply with quote
Yeah, we'd get those lines sometimes on CAD pdf drawings, but find the simple task of closing down completely and reopening the programme gets rid of them...
Don't ask me why!
Have you tried changing them to pdf from another computer (from original file)?
Deckx
PostPosted: 18:03 - 26 Feb 2010    Post subject: Reply with quote
yeah, maybe try re-boot tomorrow... got a bad habit of never switching off my computer, only put it on stand-by..
yen_powell
PostPosted: 20:31 - 26 Feb 2010    Post subject: Reply with quote
So did you use the internal PDF producer or a third part programme?
Have you still got the original CAD file? Might be worth thawing/turning on all layers to see if these lines are on the actual original drawing. If they are, make a note of the layer, use the undo command to get back to the original layer state, then turn that layer on to delete the lines before converting to PDF again.
Deckx
PostPosted: 10:49 - 28 Feb 2010    Post subject: Reply with quote
I didn't do the conversion from CAD..
Just noticed yesterday that another batch of PDFs from a different engineering company have the same problem Confused
yen_powell
PostPosted: 11:49 - 28 Feb 2010    Post subject: Reply with quote
Try pdf-ing it from CAD, I'm assuming you have got 2007 or later version. If the problem is still there you isolate the cause a little more at least.
The last post was made 16 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 65.45 Kb
