Poor rear brake.
GPZ600
PostPosted: 17:19 - 26 Feb 2010    Post subject: Poor rear brake. Reply with quote
Maybe it is because I have not ridden a bike for so long but my rear brake seems to be a bit poor.
It is a single disk so not a good as some proper road bikes with 2 disks.
The pads are fine by the inspection hole, about 5 mm left. Apparently they don't need changing until about 1mm.
No oil or grease on the disk, I cleaned it with an organinc solvent.
Maybe it's meant to be as it is and I am just used to good brakes on my car?
The front brake is brilliant (single disk) in fact almost too sharp, the forks really dive down when applied.
Quickly
PostPosted: 17:26 - 26 Feb 2010    Post subject: Reply with quote
Have you checked the brake fluid? Have you checked the cable going to the brake? Have you checked the brake lever?
PostPosted: 17:34 - 26 Feb 2010    Post subject: Reply with quote
Some bikes have shit rear brakes. Its as simple as that. There might be things you can do to sort it though...
PostPosted: 17:59 - 26 Feb 2010    Post subject: Reply with quote
Rear brakes are usually shit, because if they where too good you would be forever locking them as you don't have the control in your feet that you do in your hand. I have never seen a bike with a dual disc rear.
If you want to improve it get sintered pads and bleed the brakes, you should be using the front more for slowing down anyway.
GPZ600
PostPosted: 18:05 - 26 Feb 2010    Post subject: Reply with quote
Thanks for the replies.
Yes I have checked the brake fluid and the levle is fine.
I have lubricated all the cables but not checked them as they are hidden behind the sheaths.
The brake lever is functioning properly.
You are right about locking up, although I don't think I could lock up on this bike if I tried.
I do mainly use the front brake and slow down through the gears, just occasions like today when a cat ran out in front of me I had to really step on the brake pedal to get much response.
I'll look into bleeding the brakes in the workshop manual.
You mean air could have become trapped in the system?
lonner
PostPosted: 18:08 - 26 Feb 2010    Post subject: Reply with quote
if its something your happy to do give the calliper a service and new fluid and all should be well again.
plus check the pads are not contaminated with chain grease Thumbs Up
lonner
plus check the pads are not contaminated with chain grease oil etc Thumbs Up
wow internet going nuts Laughing
lonner
PostPosted: 18:11 - 26 Feb 2010    Post subject: Reply with quote
rule of thumb if the pistons will push back in with your fingers its the pads that are naff.
if the pistons wont budge without real force its a calliper service I'm afraid
having a few issues with the internet today it would seem lol
hth
Yeah, it happens to all brakes over time. There won't be any cables to lube if it has rear brake fluid. Silly question don;t take offence but I ask as you seem inexperianced. You are looking at the right brake fluid reservoir right? Obviously there is one on the handle bars for the front brake but there should also be one by the rear brake lever for the rear brake.
https://img.photobucket.com/albums/v295/chris-red/P1000836.jpg
In this picture you see the R&G Exhaust protector then above it the thick black tube. That tube is going up to the rear brake fluid under the seat. Yours maybe under the seat or it couple be in the rear brake master cyclinder what the thick black tube connects to at the lower end.
GPZ600
PostPosted: 18:45 - 26 Feb 2010    Post subject: Reply with quote
Thanks for the info ZZR, I'll check for grease on the pads tomorrow and look at the caliper.
Sugartits, no offence taken.
Yes I am fairly inexperienced with bikes, been many years since I had my XL600.
I do have a rear brake resevoir, the fluid level is between the low/high lines.
I lubricated the rear brake pedal, throttle cable and speedo cable after fitting a motrax convertor which I am pleased with.
As you say, no rear brake cable.
There is a bit of a ridge (1 or 2mm) on the outside of the rear disk.
Is this something I should be concerned about?
lonner
PostPosted: 20:05 - 26 Feb 2010    Post subject: Reply with quote
the ridge is there as wear has worn away the disc where the pad is in contact and although they have a wear limit i doubt you have reached it yet Thumbs Up
if the fluid in your reservoir is at that level its most likely your pads are at the end of there service life so you may need new pads and if the pistons look dirty give them a clean with brake cleaner so there shiny before you shove them back in Thumbs Up
get a manual if pos as its a really good help for basic service.
hth
GPZ600
PostPosted: 20:29 - 26 Feb 2010    Post subject: Reply with quote
Thanks for the help.
Like I said above, through the inspection hole the rear brake pads have about 5mm left each side.
I understand they don't need changing until they are at 1mm.
I'll take a look tomorrow and see if the pads are grease free and see how the pistons and calliper are.
The last post was made 16 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 74.94 Kb
