| damz |
 damz World Chat Champion
| D O G |
 D O G World Chat Champion
| and |
 and World Chat Champion
| ncrn |
 ncrn World Chat Champion
 Posted: 17:28 - 26 Feb 2010 Post subject: |
I used car engine oil once and it caused my clutch to slip a bit, the stuff they make it from is designed for car engines not for bikes.
Personally I use halfords bike oil, costs about £20 for 5 litres if I remember right, works well, engine is lubed . ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
https://www.nsr125.co.uk - NSR Owners forum. |
| MarJay |
 MarJay But it's British!
| bacon |
 bacon World Chat Champion
 Posted: 17:39 - 26 Feb 2010 Post subject: |
| ncrn wrote: | I used car engine oil once and it caused my clutch to slip a bit, the stuff they make it from is designed for car engines not for bikes.
Personally I use halfords bike oil, costs about £20 for 5 litres if I remember right, works well, engine is lubed  . |
i use semi synthetic 10w40 on my 7r, atm using castrol, was about £30 for a gallon (bit pricy), though to be honest id be inclined to use anything at the right price from silkolene, castrol etc
i actually got a HG email, they are offering gallon of oil and the filter thrown in for £20, if i was needing a change right now id go for that |
| Kickstart |
 Kickstart The Oracle
| D O G |
 Posted: 17:45 - 26 Feb 2010 Post subject: |
Aaah, two perfectly unbiased sources you've quoted there...clearly I'm wrong!  |
| and |
| Kickstart |
| and |
| temeluchus |
| Kickstart |
 Posted: 19:19 - 26 Feb 2010 Post subject: |
| ulthar wrote: | I'm not sure I follow. My understanding is that the car oils have friction modifiers to reduce friction in the engine. Motorcycle oils lack friction modifiers due to the problems which can arise with the clutch (and that they are not needed) because the motorcycle oils are lubricating not just the engine but also the clutch, valves and so on. |
Only real difference is that the oils go in the clutch. Some cars use normal engine oil in the gearbox. All lube the valves, etc.
While there might be an argument that the grinding of the oil in the gearbox will give it a harder time, the converse is that motorcycle oils are changed far more often than car oils. Oil in most Japanese bikes seems to be changed at about 4000 miles. Most cars these days seem to change the oil at about 12000 miles (and some even less often).
| ulthar wrote: | I had a look for the SG. According to API, it was introduced in 1989 and became obsolete when it was superceded by new specifications and was specified for engines from 1993 and older. The current specifications, SJ, SL and SM can be used in place of the obsolete specifications, so 10w-40 SM can be used in the ZX7R instead of 10w-40 SG. The specifications are just for petrol engines and there is no distinction made between car or motorcycle. SG refers to oxidation, wear and deposit limits. With the ZX7R using an older engine, it would retain the specifications, so I would imagine this to be the case with other bike engines and not having the updated specifications even though they can be used. |
Quite. Could use an old car oil. In theory the new oils are compatable, but it seems that some of them do cause clutch problems (Magnetec for a start, and a few people have had problems with Texaco oils I think).
I am currently using a 10W40 Rock Oil synthetic car oil, SL spec.
| ulthar wrote: | This is where things can get rediculous. Do you ignore someone who has knowledge on a subject because they are involved in it and listen to someone who has secondary information because they have no involvement in that subject? |
To an extent I agree, but those 2 articles are basically advertising. They stand to gain from people spending far more for using bike specific oil.
The Husky one just appears wrong. They claim that motorcycle oils contain ZDDP to compensate for less friction modifiers. Car oils used to contain these, but newer oil specs limit their quantities as they wreck catalytic converters (so will probably be removed from bike oils pretty soon). One advantage of the el cheapo low grade oils is that they can still contain these additives.
The Mobil 1 page appears more useful. But it just mentions 2 issues. One is how long it lasts (bike oil is changed far more often so I would regard it as a non issue) and the other seems to be talking about helping the gearbox dogs to lock together, but then some cars use these normal engine oils in their gearboxes.
Incidently, 2 of the bikes currently using car oil have each done over 20K on the stuff, and both are renowned for weak dogs in the gearbox (FZR600 and ZZR600). Both have done over 50k, while gearbox problems often occur in then in far less (in about the time these have been using car oil, let along the miles they had done in advance). Yamaha specified SE grade oil, Kawasaki specified SE or SF.
Keith[/i] ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| ms51ves3 |
 ms51ves3 Super Spammer
| temeluchus |
| The Artist |
 The Artist Super Spammer
The last post was made 16 years, 244 days ago. Instead of replying here, would creating a new thread be more useful? |
