Brake pad replacement problem
carvell
Scuttler
PostPosted: 12:55 - 02 Jul 2004    Post subject: Brake pad replacement problem Reply with quote
Righty ho.
Trying to change the front brake pads on the bros, but have hit a little problem. Got the old pads out fine no problem, but when I put the new pads in, they almost touch and there's definately not enough space for the disc to go in between them.
I've tried to push the piston thingys back in with wedges of wood and all sorts, but they refuse to budge, if i get these to go back in there'll probably be enough room for the disc and new pads.
Any idea on anything I can try to get the pistons to go in? Open the bleed nipple maybe?
Thanks for any help.
Yamaha TDM 850
WildGoose
White Van Man
PostPosted: 12:59 - 02 Jul 2004    Post subject: Reply with quote
shit bike innit Laughing
same reason my double HH pads are still on the floor and not in the caliper, if the bike doesnt want to be cooperative, then it can have lame brakes, i dont care Razz
carvell
Scuttler
PostPosted: 13:06 - 02 Jul 2004    Post subject: Reply with quote
I'm trying to fit £9.99 a pair lame brakes!
It doesnt even want them.
Yamaha TDM 850
Robby
Dirty Old Man
PostPosted: 13:09 - 02 Jul 2004    Post subject: Reply with quote
Is it a 2 pot sliding caliper?
If so, force the pistons back in with a G cramp.
Claud 14.7 to 1
PostPosted: 13:11 - 02 Jul 2004    Post subject: Reply with quote
Well if your sure that you have pushed them hard enough. When i did mine i had to push them in pretty hard...
Dont push them in quickly, only to the ammount you need...
Not sure how else, cant say anything else condifently enough .
carvell
Scuttler
PostPosted: 13:15 - 02 Jul 2004    Post subject: Reply with quote
Ummm, it has 4 piston thingys in total, 2 on each side, no idea if it's sliding or not, whatever that means!
Shall I force the things in one by one with a G clamp then?
Yamaha TDM 850
G clamp does work quite well, but make sure you push the pistons in straight. Take the cap off the master cylinder to allow the fluid back, but take care that you do not get a fountain of brake fluid from it.
You can buy things to push the pistons back. Try Partco. Only trouble is that I have only seen ones designed for cars and the blades might be too thick to fit into the caliper.
carvell
Scuttler
PostPosted: 14:24 - 02 Jul 2004    Post subject: Reply with quote
Brake pads done and system bled with the help of a G clamp.
Thanks!
Yamaha TDM 850
The last post was made 21 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 55.25 Kb
