About Yamaha XT1200Z Super Tenere
kawashima
PostPosted: 15:56 - 27 Feb 2010    Post subject: About Yamaha XT1200Z Super Tenere Reply with quote
At last XT1200Z super tenere was released on the Yamaha HP.
But I was disappointed at its wet weight of 261kg. This is +38kg heavier than TDM900.
TDM900 is a very light weight bike, and I don't need second bike(small bike), but with 261kg bike, I may want second bike sometimes.
I think Parallel twin's pros are compactness and lightness.
I hope yamaha will make TDM1200 and TRX1200 with lighter weight.
What I'm curious
-Bottom end torque
(TDM900 doesn't have enough bottom end torque.)
-4valve
(TDM900 was 5valve)
-Wind protection
Wind screen doesn't look so big.
What do you think of this 1200cc bike/engine?
own:2020 Serow 250
PostPosted: 16:01 - 27 Feb 2010    Post subject: Re: About Yamaha XT1200Z Super Tenere Reply with quote
It seems appropriate as a competitor for the BMW GS, but not really my thing - I'd prefer a competitor to the F800GS/KTM990.
Itchy
PostPosted: 16:05 - 27 Feb 2010    Post subject: Reply with quote
Its a road bike...
Its a replay of 4x4 type cars, in that the big cc adventure bike was popularised by LWR and people who will never take them off the road buy them, i.e is it bandwagoning for fashion purposes. A bloke nearby for example I went on a ride out with him, he has a BMWGS he turned round when the road was slightly wet with leaves, I was on the CBR and continued on my merry way.
Granted there is a small portion of bikers and 4x4 drivers who will take such bikes off the road, such as the polish blokes who did the BAM road on Africa twins and Tiffany who took her 280kilo bike around the world 4 times. But the number of people who do this stuff vs those who will just ride them on the road is limited.
Most people will keep them on the road and thus the off road performance and the weight isn't an issue.
This has been repeated lots of times, hard alloy panniers for example were popularised by LWR, the Zega ones are good, but tons of people have them for fashion purposes and they fall apart as they are badly made.
While for adventuring people will use whatever is to hand, like that SR500 I saw in Siberia which had no ground clearance at all and was so heavily overloaded it had no suspension travel, or that silly sod I saw on the Mongolian Steppe on a fairly new goldwing.
Had a look on the Yam website defo a road bike:
Close fitting front mud guard low ground clearance, exceptionally vulnerable radiator / CDI, plastic cases, Shaft drive (hard to fix OTR) Low exhaust, acres of plastic to break no gators and short travel suspension.
Given the choice of a 20 year old XTZ750 I'd take the XTZ750 which weighs much less and has been proven (some bloke took one across the Sahara).
Nyarlathotep
PostPosted: 18:52 - 27 Feb 2010    Post subject: Re: About Yamaha XT1200Z Super Tenere Reply with quote
I was looking forward to this bike. Then I saw the price: £13,500.
Honestly, at that price, I don't care what the bike is like. It's never going to be worth it!
PostPosted: 19:15 - 27 Feb 2010    Post subject: Re: About Yamaha XT1200Z Super Tenere Reply with quote
kawashima wrote:
TDM900 is a very light weight bike...
Is it? Wink
kawashima
PostPosted: 01:33 - 28 Feb 2010    Post subject: Re: About Yamaha XT1200Z Super Tenere Reply with quote
Wow! That's too expensive! Shocked Shocked Shocked I agree with you.
ms51ves3 wrote:
Is it? Wink
I think I feel so because the mass is concentrated compared to other bikes like litre IL4 naked.
own:2020 Serow 250
and
PostPosted: 01:43 - 28 Feb 2010    Post subject: Reply with quote
pa_broon74
PostPosted: 03:09 - 28 Feb 2010    Post subject: Reply with quote
It looks like a varadero, to fat for proper off road use.
Why would you need 1200cc for rough roading anyway, even for dual use it makes little sense. My 650 sits at 80 quite happily on motorways indefinitely.
I might be biased though, I like my wee single cylinder bikes.
Didn't catch anything.
Smooth
PostPosted: 11:17 - 28 Feb 2010    Post subject: Reply with quote
If the BMW GS is equivalent to a Range Rover, the Tenere 1200 is the equivalent to an (BMW) X5 with, er, phat alloys.
TDM850
Itchy
PostPosted: 12:14 - 28 Feb 2010    Post subject: Reply with quote
I think its generally the old thought of tarmac time vs off road time, in that to get to say somewhere adventury overseas relatively close the Kaparthian mountains or the Pryanees, you have to spend two or three days just getting there which on a proper trail bike is literally a pain in the next, hands and back.
PostPosted: 12:16 - 28 Feb 2010    Post subject: Reply with quote
That's more to do with fairings than power, I'd say.
My KTM will sit at 100mph or so, though really need higher gearing and a fairing to do so comfortably.
pa_broon74
PostPosted: 18:38 - 28 Feb 2010    Post subject: Reply with quote
Agreed. My BMW will sit at 100mph, but it could do with another gear. It's also the most comfortable bike I've owned.
I've had it off road once or twice, but can't really comment as I have no frame of reference.
PostPosted: 18:57 - 28 Feb 2010    Post subject: Reply with quote
Annoyingly what my KTM more needs than an extra gear (it has six already) is wider ratios - I believe the GS (if it uses the same gearing as the G650) actually has a wider differentiation between first and top gear.
The KTM is fine geared for a (theoretical) top speed of around 125mph for road use, but ideally I'd have a lower first gear than standard for off-roading along with the higher top.
hmmmnz
PostPosted: 21:38 - 28 Feb 2010    Post subject: Reply with quote
its a shame they have fucked this up so badly,
its wicked that it has a shaftie, and side mounted rads, but i have no idea how they managed to get the bike up to 261kg, thats heavier than my v4 vf1000 form the early 80's
they really needed to put a 21" on the front, increased the suspension travel, given the bike a bit more clearance,
and done away with about 60kg
the ktm990 adventure r is so much more bike for the money
even the bmw is a better all round bike
im not sure how yamaha has managed to make a more compact engine but still managed to make the bike 50kg heavier than the other 2 big names
Thumbs Down i won't be buying one
the humans are dead
I kick arse for the lord
PostPosted: 22:05 - 28 Feb 2010    Post subject: Re: About Yamaha XT1200Z Super Tenere Reply with quote
ms51ves3 wrote:
Is it? Wink
yep
It's 190kg dry
Considering it's size that is impressive.
Lighter than a 650 blandit and only 20 or so kg heavier than most 600cc Supersports bikes.
BanditJeff
PostPosted: 23:20 - 28 Feb 2010    Post subject: Reply with quote
I dont see that shaft drive is wicked at all. They may be easier to live with, and have none of the hassle of oiling and adjusting a chain. But when shaft drives fuck up, they fuck up in a spectacularly expensive way, not to mention the fact that they sap power and are harder on rear tryes.
You cant get much simpler than chain & sprockets and even BMW put them on their new F800GS.
PostPosted: 00:14 - 01 Mar 2010    Post subject: Reply with quote
I would have said belts are simpler less moving parts and less maintainence.
hmmmnz
PostPosted: 00:32 - 01 Mar 2010    Post subject: Reply with quote
when you have 100 odd horseys, on an "adventure bike" whats a couple being soaked up by the shaft drive system,
and as for simpler, well that may be, but the clearly isn't the route that yamaha have taken, i like shafties, their is something inherently manly about having a huge drive shaft and a diff Very Happy
as for them going wrong... well like anything do the maintenance and you rarely have trouble, ignore it at your wallets peril Very Happy
the humans are dead
PostPosted: 00:44 - 01 Mar 2010    Post subject: Reply with quote
A diff Confused - surely it's just a basic gear, what with there not being two wheels getting power?
I wouldn't have an issue with them on such bikes, apart from the weight penalty, which is pretty important to my mind.
Oh and telling people you ride a 'big shaftie' has never been my idea of manliness Razz.
Itchy
PostPosted: 00:56 - 01 Mar 2010    Post subject: Reply with quote
there is a biggie issue with a shaft drive aside from weight though, in that you can change the sprockets to alter the gearing easily with a couple of tools and sprockets which will fit into your pocket. High gearing for cruising and uber low gearing for the rough stuff, sometimes 1st just isn't low enough and 5th or 6th not high enough. Until they can invent a variable shaft drive, even though I'm a fan of shaft drives due to laziness, I'd not be happy with it.
hmmmnz
PostPosted: 01:25 - 01 Mar 2010    Post subject: Reply with quote
ok worded wrong on my part, its not a diff, a bevel drive and crown wheel.... half a diff Very Happy
and not really manly because you say you have one, but manly in the way they look,.... and weigh Very Happy ok may be that's just me, but i like it on a guzzi and beemer,
and with the way that guzzi's and beemers are set-up they make sense, not really so on a parallel twin mounted horizontally, thats just adding parts for the sake of it,
the humans are dead
Dom
PostPosted: 12:17 - 11 Mar 2010    Post subject: Reply with quote
I have to say, I think it looks fucking cool. The idea of an adventure bike with Japanese reliability is very appealing too. By the sound of it it'll be far too heavy to take off road though, and a side-mounted rad seems like the kind of idea that hasn't been tried before simply because it's stupid. By the sound of it it's a good 60kg heavier than my 950!
If I was in the market for a GS this would definitely have me aiming for a Yamaha dealer instead though:
https://www.yamaha-motor.co.uk/Images/2010-yamaha-XT1200Z-Super-Tenere_VPBC5_studio_006_tcm46-356219.jpg
It's just a shame there won't be any demo bikes cause I'd love to give one a try. I bet it would be a lot of fun on the road, but the weight thing would put me right off taking it out on muddy stuff, which seems to render the whole thing pointless. Why not get a bike which will be similarly good/better on the road like a Multistrada, Tiger or Varadero?
And that price… Shocked
Photos and that
PostPosted: 12:31 - 11 Mar 2010    Post subject: Reply with quote
It looks good I just wonder about the weight, I wouldn't want something much heavier than the TDM.
PostPosted: 12:32 - 11 Mar 2010    Post subject: Reply with quote
Hondas 1800 goldwing has side mounted radiators
Triumph Trophy Launch Edition
Dom
PostPosted: 12:33 - 11 Mar 2010    Post subject: Reply with quote
Fair enough. That is basically a car, though. Honda's not suggesting you can do this on it:
https://www.yamaha-motor.co.uk/Images/2010-yamaha-XT1200Z-Super-Tenere_VPBC5_action_002_tcm46-356148.jpg
Photos and that
The last post was made 16 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 142.44 Kb
