Syncing carbs
Ichy
PostPosted: 15:30 - 28 Feb 2010    Post subject: Syncing carbs Reply with quote
One of those where you keep going around in circles.
I've finally rebuilt the CBR6 and decided to sync the carbs. Originally I did them at tickover, around 1k and all was good. Having played around I noticed that the vacuum changes as you rev the bike, at 3kish the two center carbs have a higher value than the two outers.
I'm interested in peoples opinions on where you should actually set the carbs so that they synchronise. Personally I think 5k is about right since that is where you ride the bike for a fair bit of the time. Does it make that much difference? The cbr is notorious for vibrations through the bars so it makes sense to me.
yen_powell
PostPosted: 15:51 - 28 Feb 2010    Post subject: Reply with quote
It's only at tickover and just above that they need to be synchronised.
XT1200Z and a DR350 in bits
Ichy
PostPosted: 16:39 - 28 Feb 2010    Post subject: Reply with quote
why?
Its not always true, one I can think of straight away is the XV virago. You are supposed to synch the carbs at tickover and at 3k.
PostPosted: 16:52 - 28 Feb 2010    Post subject: Reply with quote
Not sure there is any point to trying to balance them at higher rpm. On bike carbs the syncing just adjusts the throttle plates to each other, and with any reasonable amount of throttle the difference the adjusters will make will be nominal incomparison.
Added to which to hold 5k without any load takes virtually no throttle at all, while 5k in real riding would likely to a significient amount of throttle (and how much would depend on the load, gear, etc).
lonner
PostPosted: 17:05 - 28 Feb 2010    Post subject: Reply with quote
on most bikes its around 1100 1200 rpm but this little srad 600 ive just got is set at 1750 to get it right.
with most bikes you must block off the pair valves which im sure you did if fitted Thumbs Up
but as said synchronizing carbs throttle boddies etc is only relevant at low rpm with the butterflies in the closed position Thumbs Up
once the revs have risen its down to mixture and the needle valve operation to give you smooth running.
Ichy
PostPosted: 18:06 - 28 Feb 2010    Post subject: Reply with quote
I removed the pair valves completely. ZZR, makes complete sense since the inner carbs have a different jet to the outer, probably the reason for the difference in the vacuum. Thumbs Up
lonner
PostPosted: 21:05 - 28 Feb 2010    Post subject: Reply with quote
The last post was made 16 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 52.41 Kb
