Problems idling :(
sms_sms
PostPosted: 15:18 - 28 Feb 2010    Post subject: Problems idling :( Reply with quote
Hi guys, it's been a long time - haven't had a bike for a few years!
I need to suck some knowledge out of your brains if you dont mind... Laughing
I've got a chinese 125 (yes I know Rolling Eyes - but it is one of the better ones) and recently have developed idling issues.
It was a gradual problem i.e. the last few times I rode it I had to keep kick starting it a load of times to stop it dying and get it to keep running until it basically wouldn't start up one day.
I have cleaned the carb with carb cleaning spray, adjusted the tappets, changed the spark plug for a new one, changed the oil, installed an in-line fuel filter, and put a bit of ispropyl alcohol in the tank to stop anything icing up. Battery is fine at 12.5V. And I swapped the stock air box for a K&N style cone filter while I was there Smile
Fast forward to yesterday.. Shocked
It ran for a fair while, 5-10 mins but then stalled so I restarted it, didn't seem to be any problems then.
Took it for a spin and after a while it starting having problems when I pulled the clutch in or stopped and you could hear it start to die so I had to keep revving it to stop it dying luckily I got home Very Happy
The thing is, the idle problems seem to be alot worse when the engine is warm :S
Checked the spark plug after the test run and it was grey/brown.
Any ideas guys?
Update: Ran again, ran fine for about 5 mins then died and continued to die when restarted. Ran without fuel cap, didn't make a difference. Seems to be a problem when it's warmed up to a certain point. Weird... Confused
P.
PostPosted: 15:34 - 01 Mar 2010    Post subject: Reply with quote
adjusted carb for that cone filter you added??
chip
PostPosted: 15:46 - 01 Mar 2010    Post subject: Reply with quote
remove that inline fuel filter and try again
sms_sms
PostPosted: 16:12 - 01 Mar 2010    Post subject: Reply with quote
Yep, plug is a nice browny colour. How would removing the filter change anything? There's enough fuel getting through.
It revs fine its just the idling thats the problem.
slyrob
PostPosted: 16:18 - 01 Mar 2010    Post subject: Reply with quote
Have you checked the choke cable/assembly?
Pitslayer wrote "it could be Ndubz.....ruining this once great place with donkey gobbling loafer knobbing "music".
silky666 wrote "In my eyes, when you shake cocks with the devil, you may as well go for the full reach around"
Villers wrote "as reliable as a ginger stepchild on smack"
Gawain
PostPosted: 16:20 - 01 Mar 2010    Post subject: Reply with quote
You could try adjusting the mixture screw, Iv found its very sensitive when the airbox is fiddled with.
Mixture screw is under the carb nearest to the engine vertically orientated and a pain to get to. Use a stuby screw driver. Turn it in all the way gently counting the turns, remember this figure. Reset back.
Warm bike up properly and adjust mixture screw in/out until the idle is at its smoothest/fastest.
sms_sms
PostPosted: 16:40 - 01 Mar 2010    Post subject: Reply with quote
I've adjusted the mixture screw to its best Smile
I even turned up the idle screw to about 2.5k but it cut out when it got warm again so it's not a blockage in the carb or jets and the choke assemblys fine as I inspected it when it was off.
To be honest I think it's either the valves (which I've adjusted) and the mileage is about 500 miles so I don't think it's that, or its a faulty electrical component.
Does anyone know of an electrical component that might work fine but stop working properly when its warm?
sms_sms
PostPosted: 16:48 - 02 Mar 2010    Post subject: Reply with quote
Never mind folks, looks like it was the tappets. Can't believe they closed up so much over 500km!
The last post was made 15 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 55.59 Kb
