XBOX 360 one red light problem , help!!
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2, 3  Next
Graprilia
PostPosted: 20:00 - 01 Mar 2010    Post subject: XBOX 360 one red light problem , help!! Reply with quote
My brother 360 has the one red light problem , does anyone know how to fix it?
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
lllN30lll
PostPosted: 20:04 - 01 Mar 2010    Post subject: Reply with quote
Indeed. Cool
Turbo R1
CRF450R
Graprilia
PostPosted: 20:26 - 01 Mar 2010    Post subject: Reply with quote
Indeed.
How?
lllN30lll
PostPosted: 20:28 - 01 Mar 2010    Post subject: Reply with quote
Console Failures, RRoD
Sections 1, 2, 3, and 4 are flashing red
- The AV cable cannot be detected
THINGS TO TRY
* Make sure that the AV cable is correctly connected to the Xbox 360 console.
* Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
* If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
* If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Sections 1, 3, and 4 are flashing red
- General Hardware Failure
Check the secondary Error Code per the instructions in the section below
THINGS TO TRY
* Try restarting the console.
* If restarting the console does not resolve the behavior, follow these steps:
o Turn the console off.
o Unplug all the power and AV cables from the console.
o Unplug the power cord from the wall socket.
o Firmly reconnect all the cables.
o Turn on the console.
* If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
* Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
Sections 1, and 3 are flashing red
- Overheating
Alternatively Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
* Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
* Verify that the console has sufficient ventilation and that the fan is operating. For more information about ventilation, see the "More Information" section.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
A more aggressive Solution to overheating is to improve the cooling system of the console. The best solution is to replace the thermal compound. If you attempt this you do so at your own risk. If you're console is still under warranty it is recommended that you contact MS for a replacement before attempting to fix it yourself.
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E01: possibly a power supply problem
E02: possibly a Network Interface problem (might be fixed by loosening the x-clamps)
E03: possibly Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
E04: Unconfirmed: There is a problem with the Southbridge Chip usually dealing with how it connects to the mainboard (cold solder joint/bridged solder joints)
E05: CPU over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsinc screws are tightened securely to the board/heatsink holes.
E06: GPU over heating -ensure your x-clamps are installed properly.
E07: RAM over heating
E08: Unconfirmed: General I/O Malfunction, could be caused by an error with any of the I/O devies such as A/V port, USB, Hard drive, DVD drive, etc. over torquing of the AV or heatsync bolts can cause this error.
E09: Unconfirmed: This can be caused by two completely different things either:
A. DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard based on how it connects to the DVD drive.
B. GPU error, generally caused by a poor connection to the mainboard (cold solder joints/bridged solder joints) See error E18 for more information
E10: Unconfirmed: CPU error, generally caused by a poor connection to the mainboard (cold solder joints/bridged solder joints). This can also be triggered by an error with the TSOP.
E11: (not yet known)
E12: Possibly a problem with temperature control
E13: Unknown: could be caused by a short between the heatsink and surrounding capacitors
E14: (not yet known)
E15: (not yet known)
E16: Unknown: Likely a cold solder join in GPU or Ram chips (see error E18)
E17: (not yet known)
E18: Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
E19: Unknown: GPU Error this is usually caused by bridged solder points where the GPU connects to the mainboard. see error E18 for more detailed information
E20: likely a Ram error, this can be caused by a cold or bridged solder joint on one of the Ram chips.
E32: (not yet known)
E33: (not yet known)
E34: (not yet known)
E35: over heating GPU possibly due to lack of thermal compound.
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error - Dvd drive timed out during reset :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot. also it could mean that the Kernel can't be launched/signature in NAND Flash chip is broken It could be possible after bad update. https://forums.xbox-s...p;#entry4156375 This might also be caused by a bad SATA cable.
E65: DVD Drive Error - Dvd drive is not DMA configured :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error - Dvd drive pairing failure: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer. if drive can eject, read, and write under windows but errors on console, replacing original firmware should fix issue.
E67: Hard Drive Error - Hard drive timed out during reset: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
E69: Hard Drive Error - Reading the HD Security sector failed: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E70: Hard Drive Error - Hard drive not found
E71: Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: Dashboard Error - Error within Xam.xex: Like a problem with the NAND flash
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
E74: I/O Hardware Error - HSIO related, could be crc error, or many things: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. Microsoft covers this error under their 3-year warranty, this is availble to anyone who hasn't modified their console. contact MS to get a free replacement console before attempting to fix this yourself. Failing that this error In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error 0102)
E75: Ethernet Error - Couldn't read ethernet phy vendor: Strange but sometimes caused by the DVD drive not being connected properly.
E76: Ethernet Error - Couldn't complete ethernet reset: This error is usually cased by the Ethernet port's controller chip, a dead chip may not cause the error but removing the Ethernet controller chip does, it may also be caused by other Ethernet related problems.
E77: Ethernet Error - phy request is already processing/reading reg failed/Failed to write reg: This error is sometimes caused by power problems with the RAM chips. It might be cause by a short between the heat sink and resistors or by more serious problems with the RAM. [more info]
E78: Dashboard Error - AsicId check failed
E79: Dashboard Error - Couldn't start xam.xex: probably a file system corruption, it could also be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
E80: Dashboard Error - Wrong LDV version in NAND Flash: This is in new dashboard. You have the update but haven't R3T6 resistor. You can:
-Downgrade to old dashboard, solder back the resistor and then update your xbox
-If you have CPU Key, get current NAND Flash image and fix LDV (just add 1 up to latest kernel). (See error 1100)
--==SECONDARY ERROR CODES==-
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 3 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code (as described below).
* Release the eject button and press it again.
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
* All four lights flashing - 0
* One light flashing - 1
* Two Lights flashing - 2
* Three lights flashing - 3
0001 See Error E01
0002 See Error E02
0003 See Error E03
0010 See Error E04
0011 See Error E05
0012 See Error E06
0013 See Error E07
0020 See Error E08
0021 See Error E09
0022 See Error E10
0023 (not yet known)
0030 See Error E12
0031 See Error E13
0032 (not yet known)
0033 (not yet known)
0100 See Error E16
0101 (not yet known)
0102 See Error E18
0103 See Error E19
0110 See Error E20
0200 (not yet known)
0201 (not yet known)
0202 (not yet known)
0203 See Error E35
1000 See Error E64
1001 See Error E65
1002 See Error E66
1003 See Error E67
1010 See Error E68
1011 See Error E69
1012 See Error E70
1013 See Error E71
1020 See Error E72
1021 See Error E73
1022 See Error E74
1023 See Error E75
1030 See Error E76
1031 See Error E77
1032 See Error E78
1033 See Error E79
1100 See Error E80
1444 and up There is no "4" in the error codes. Four lights is a "0" go back and check your code again.
--==Power Supply Color Codes==--
no light - No Power - Power supply is not receiving power from the mains
Green - Power On - Power supply is plugged in and receiving power from the mains and the console is powered on.
Orange - Stand By - Power supply is plugged in and receiving power from the mains but the console has not yet been powered on.
Red - Power Supply Error, Power supply is plugged in and receiving power from the mains, but there is a problem preventing it from delivering power.
this can be caused by the following:
* overheating - this is commonly caused by lack of ventilation, check to make sure there is a lot of open space around the power supply, that the air temp in the room is cool, and that the vents are free from dust and debris. Also check to make sure the fan is still functioning properly
* incorrect voltage - this can be caused by the power supply being plugged into an outlet that is not providing the proper voltage for the power supply to function properly.
* too much current draw - this means that the console is drawing too much power from the power supply. This is most commonly in modded consoles this can be caused by excessive LEDs or other extraneous hardware, in non-modded consoles this most often caused by short somewhere; a common problem is USB ports that have been damaged and the pins inside the port are shorting out on each other.
--==Console Reset Codes==--
Clear All Installed Game Updates and Console Cache
* Go to the "system" blade
* Select "memory"
* Press Y on the HD symbol
* Press X,X, Left Bumper, Right Bumper, X,X
* A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
* Select Yes
Clear Any Failed system updates that cause the console to error.
* With the console off, press and hold the sync up button (the small white one)
* While holding the sync button press the power button to turn on the console
* Continue to hold the sync button until the Console has booted up completely.
* During the boot process the console should clear any failed updates, allowing you to use it normally.
--==Sending in your Console for Repair==--
If none of the above suggestions work, contact MS customer support get get a support ticket started. If your console is still under warranty DO NOT attempt to open it and fix it yourself. MS will fix it promptly and for free and if you open it you loose the free support.
Check the documentation that came with your Xbox 360 for contact information.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Turbo R1
CRF450R
Graprilia
PostPosted: 20:45 - 01 Mar 2010    Post subject: Reply with quote
thanks mate , it is the following :-
lllN30lll
yup, either Xclamp it, or send it off to MS.
Turbo R1
CRF450R
Graprilia
PostPosted: 20:46 - 01 Mar 2010    Post subject: Reply with quote
how easy is it to x-clamp it?
lllN30lll
PostPosted: 21:01 - 01 Mar 2010    Post subject: Reply with quote
https://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
Turbo R1
CRF450R
Graprilia
PostPosted: 21:03 - 01 Mar 2010    Post subject: Reply with quote
Thanks alot , i shall read though that tomorrow
TomCB
PostPosted: 22:03 - 02 Mar 2010    Post subject: Reply with quote
if its still in warrenty, send it off for repair.
https://support.xbox.com/support/en/us/nxe/kb.aspx?id=969905&lcid=1033&category=hardware
Faldo: "Classic BCF. A thread about sky diving is NSFW on post #2."
lllN30lll
PostPosted: 22:13 - 02 Mar 2010    Post subject: Reply with quote
TomCB wrote:
I already said that Doh!
Turbo R1
CRF450R
Graprilia
PostPosted: 12:54 - 07 Mar 2010    Post subject: Reply with quote
i attempted the repair and it didnt work still have the one red light and now the fan speed continuely gets faster and faster which is wierd.
So i looking to get a new one but dont which model is the most reliable as i see even the new elites get RROD , any suggestions on the best model to get?
lllN30lll
PostPosted: 13:02 - 07 Mar 2010    Post subject: Reply with quote
First things, did you use a good quality silver based paste?
are the heatsinks definitely on tight with the correct washers?
The RPM of the fans will increase because the heat is building up so quickly, normally when a heatsink isn't seated properly or the fan tunnel isn't on.
Turbo R1
CRF450R
Tarmacsurfer
PostPosted: 13:10 - 07 Mar 2010    Post subject: Reply with quote
Mine died of an E74 recently as well, luckily it was still in warranty. The down side to this was it meant I didn't get to open it up and play.
Personally I still favour the elite, the black casing appeals to the emo in me.
How did your JTAG experiment go, N30?
If the broken 360 is for sale then I may be interested, let me know how much your brother wants.
I'm immortal. Well, so far.
Rob W
PostPosted: 13:21 - 07 Mar 2010    Post subject: Reply with quote
I dont think any of them are more reliable than any others. I went through 3 of them pieces of shit before I finally gave up and got myself a 250GB PS3 Slim.
Not to say this wont go wrong but I refuse to pay any more money for a console that MS blatantly know isn't reliable, and yet still do nothing about.
Graprilia
PostPosted: 14:22 - 07 Mar 2010    Post subject: Reply with quote
I was send "the best thermal paste available" apparently and the heatsinks are on finger tight.
Feel free to make an offer and i will let him know.
Groove
PostPosted: 14:25 - 07 Mar 2010    Post subject: Reply with quote
Ive had my xbox 360 around 3 years and never had a problem.
Am i lucky? Confused
Graprilia
PostPosted: 15:17 - 07 Mar 2010    Post subject: Reply with quote
UPDATE: Red light problem is no more - just tightened the bolts up fully with a spanner.
However the fan is still continually increasing in speed and i have double checked it is fitted correctly is it worth buying a new one to put in?
lllN30lll
PostPosted: 15:36 - 07 Mar 2010    Post subject: Reply with quote
was there washers between the heatsink and the board? did you tighten the screws corner to corner?
Turbo R1
CRF450R
lllN30lll
PostPosted: 15:38 - 07 Mar 2010    Post subject: Reply with quote
Perfect mate, £13 for the console, and £58 quid for the hard drive.
Even drunkenly bodged the 500gb hard drive inside the console Laughing
Just FTP'ing every single XBox live arcade game over, and some DLC for Borderlands.
https://photos-c.ak.fbcdn.net/hphotos-ak-snc3/hs408.snc3/24687_10150116826210212_671540211_11561099_5974559_n.jpg
Turbo R1
CRF450R
Tarmacsurfer
PostPosted: 16:07 - 07 Mar 2010    Post subject: Reply with quote
Ahh, if you've got it working then don't worry. I'll see what I can find on Ebay Thumbs Up I was just looking for something to strip and play with and possibly see about flashing if it could be ressurected.
@N30: Nice going. I've been keeping an eye out for a system to use for it but had sod all luck finding one, been trying to work out if any of the after market chips will allow an updated 360 to be JTAG enabled.
lllN30lll
PostPosted: 16:18 - 07 Mar 2010    Post subject: Reply with quote
No mate, all the chips need the old dashboard.
If you look for XBox 360 JTAG on eBay, you'll find consoles that will say JTAG'able, but some go for silly money.
Turbo R1
CRF450R
Graprilia
PostPosted: 16:35 - 07 Mar 2010    Post subject: Reply with quote
UPDATE : i took it apart again to find i had three washers on one side and only one on the other so i switched that around so i had 2 all the way around and put it all back together to find the FAN is now working fine but the RED LIGHT is back ffs.
lllN30lll
PostPosted: 16:36 - 07 Mar 2010    Post subject: Reply with quote
have you "baked" it?
FOllow the last few steps of this Tut.
Make sure to keep an eye on the time your doing it.
Turbo R1
CRF450R
Graprilia
PostPosted: 16:40 - 07 Mar 2010    Post subject: Reply with quote
so basically i need to remove the fan shroud but still have the fan connected and let it run for 40-45mins?
Or disconnect the fan as well?
The last post was made 16 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 151.02 Kb
