Paddock stands
moto
PostPosted: 11:40 - 02 Mar 2010    Post subject: Paddock stands Reply with quote
Do any of you trail bike riders use these type of paddock stands?
https://www.ghostbikes.com/products/Accessories-Bike-Stands/1076-Oxford-Front-and-Rear-Motorbike-Paddock-Stands.html
I have an XL600 and would prefer to use those type that go under the swing arm and forks. Or are they just for road bikes?
I am not keen on the motorcross bike lift/stand that goes under the engine and because the XL is not as high as most MX bikes it wont fit under anyway.
PostPosted: 14:09 - 02 Mar 2010    Post subject: Re: Paddock stands Reply with quote
Why aren't you keen? They let you do more work (take the front/back end off etc) are less hassle and generally easier to use.
Any half decent one will start low or have adjustable height.
I've got a hydraulic scissor lift and a 'norma' one hydraulically damped. No problem using either on everything from a Gas Gas Pamp' (low) to both my KTMs (one fairly heavy, the other very high.)
You can use the road ones, but they can be a little less stable due to the higher CoG, just can't understand why you'd want to when there's better options out there - if you've got a badly designed skid-plate it could be a reason to do so.
moto
PostPosted: 14:24 - 02 Mar 2010    Post subject: Reply with quote
Well the main reason is because I thought the paddock stands looked more stable, but maybe I am wrong about that.
I have just been out and looked under the bike, it has a flat surface under the engine where a mx lift/stand could be placed.
I was more concerned that the bike would be unstable and rock.
The other problem is the lowest lift/stand I can find is 12". (I have emailed a few companies)
It needs to be 10" to go under the XL.
PostPosted: 14:40 - 02 Mar 2010    Post subject: Reply with quote
I find that normal front paddock stands often aren't that stable and you have to get decent ones to be stable at the rear. Only time I've had a problem with dirt bikes is the KTM 690 with it's standard plastic skid plate that's a bit dodgy in the angles.
This one goes down to 10":
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150419265843
Even if it's a bit low, slightly lifting the bike off the suspension isn't too hard as you slide the stand under the bike - I have had to this on the 690 when it's loaded. But it also means the bike sits upright on it when it's at the bottom too, which can be useful.
A conventional paddock stand probably would be a little more stable, but not enough to worry about I'd say.
The hydraulic scissor ones I found on ebay claimed to be a minimum of 340mm, they look the same as mine. If that's the case, I still haven't had a big problem getting the lower bikes up to that high either. Though, to be fair I am generally fairly happy man handling bikes.
BlackStallion
PostPosted: 14:49 - 02 Mar 2010    Post subject: Reply with quote
Just to let you know mate, i had that exact rear paddock stand, cost my mate £64.99, he gave it to me because he had sold his bike, and since i didn't have a paddock stand, i accepted it and gave him a tenner for it.
Anyway, i got home, went to use it so i could clean and lube my chain the painless way, and it didn't even lift my rear wheel off the ground Shocked it raised the bike ever so slightly, but the wheel couldn't spin freely, so it was useless Thumbs Down
I found it pretty shocking, especially for an Oxford product at that price. Baring in mind my bike is a 125 enduro/trail, they must be built slightly higher off the ground than sports bikes, to allow for off road manouvreability.
I gave it away and ended up buying myself a cheap universal one off eBay for about £25 and it does the job perfectly.
This is my bike i tried lifting with the Oxford stand:
https://i657.photobucket.com/albums/uu299/milkster125/P171009_153101.jpg
PostPosted: 14:57 - 02 Mar 2010    Post subject: Reply with quote
Good point, forgot about that as my current 'sports' paddock stand is a bit higher than others maybe, so about works ok. Though, think with really knobbly tyres or 19" rear wheels it wouldn't. May have issues with the front too, on that - as it'll probably have a 21" wheel.
Have had similar issues in the past with other stands.
One of the issues with dirt bikes is the swing arm tends to angle up more, so you can't push it very far past the swignarm spindle before either.
moto
PostPosted: 15:53 - 02 Mar 2010    Post subject: Reply with quote
Some really helpful information there guys, thanks.
Good to hear of your experiences with the different types of stands.
As you say G I should be able to lift the bike enough to get it onto a motorcross stand/lift.
So after all that I think I will go for a MX stand that sits under the engine.
moto
PostPosted: 22:10 - 05 Mar 2010    Post subject: Reply with quote
Got my DRC HC2 Stand today.
It is still about 10 mm too high but putting a block of wood under the front wheel allows it to slide under the engine protector.
It is a sturdy bit of kit but I do find the gear changer and footrest are in the way of the foot/jack pedal.
PostPosted: 22:16 - 05 Mar 2010    Post subject: Reply with quote
I presume you have adjusted it all the way down?
I often don't have the stand sticking straight out at the side and haven't had a problem - so you could try angling it a bit if levers are getting in the way.
moto
PostPosted: 09:39 - 06 Mar 2010    Post subject: Reply with quote
The XL is just about 10mm lower than the stand.
Yes it is right the way down but not a problem to get it underneath.
I tightened the chain with it on the stand yesterday.
I did find it wobbled a bit when I was untightening and tightening the axle nut but I suppose in future I could untighten it before jacking it up.
Overall I am pleased with it.
The last post was made 16 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 64.52 Kb
