brake light not working??
stevekingchef
PostPosted: 23:18 - 08 Mar 2010    Post subject: brake light not working?? Reply with quote
hi guys
just put my triumph tt600 in garage before it goes off to the dealers to fix starting problem!!
I noticed when i pull the front break leaver the light does not work?
when i press the rear brake it lights up fine.its mot time and i need to try to fix asap?
any ideas??
many thanks for your time guys
steve
PostPosted: 23:21 - 08 Mar 2010    Post subject: Reply with quote
the button on the brake has gone?
i find mine clicks when i pull it in, guessing thats the button for the rear brake light to come on.
stevekingchef
PostPosted: 23:38 - 08 Mar 2010    Post subject: Reply with quote
the button??
not too sure what u mean by that?
kingsmith
PostPosted: 23:46 - 08 Mar 2010    Post subject: Reply with quote
probley mean the switch that works the break light.
be on the handle bar right next to the lever.
best way is disconect the wires and touch them together with ignition on brake light should come on , if it does then the switch is fucked/rusty etc etc, if not check the wires might have a brake in there somewhere?
mine went on the back last week a wire had snapped and the switch was badly coroded so stripped it down and cleaned and greased it up...
easy to do mate..
barry Thumbs Up
good luck
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
stevekingchef
PostPosted: 00:01 - 09 Mar 2010    Post subject: Reply with quote
cheers will try tomorrow
steve
neil.
PostPosted: 07:00 - 09 Mar 2010    Post subject: Reply with quote
If it is the switch, try cleaning it up with some isopropyl alcohol or contact cleaner (spray it on and work the switch vigorously). Silicone grease all over it afterwards will help stop corrosion in the future.
The last post was made 16 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 46.93 Kb
