| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 13:24 - 04 Mar 2010 Post subject: Runs - Dies - Runs - Dies - Runs etc etc |
Hi all
I was hoping what ideas you might think I have with this problem.
Its a Honda H100S2 model (2T smoker)
Symptoms: It will start, run for about 5 secs then die!
Solutions so far:
It had a new plug, the spark is strong and it did the same thing on the old and new plug so I have ruled that out!
Starting requires a lot of choke and i might get a brief run, then choke in, runs as normal then dies!
What is the problem I'm not sure but I'm guessing the carb needs a strip down and clean?
Thing is it has ran great for the last 6 months after coming out of storage for 12 years!!!
Any pointers? And just so you know its not a points ignition system! CDI cheers in advance for any help!  |
| lonner |
 lonner Spanner Monkey
 Posted: 13:32 - 04 Mar 2010 Post subject: Re: Runs - Dies - Runs - Dies - Runs etc etc |
| cb1rocket wrote: | Hi all
Solutions so far:
sounds just like me at the gym
is the baffle blocked?
also id check for air leaks but im thinking crank case seals are worn.
thats why it runs with choke and dies when choke off as mixture is too lean with the extra air leaking past the crank seals. |
| cb1rocket |
| cb1rocket |
| Pete. |
 Pete. Super Spammer
 Posted: 21:29 - 04 Mar 2010 Post subject: |
My dad had a H100 years ago, would barely run. Turned out the exhaust was completely blocked. I diagnosed it by unscrewing the exhaust header. Made loads of noise and had loads of go. I de-coked the exhaust after that to fix it.
I think your problem is fuel starvation. Turn the tap off and take the fuel hose off the carb. Turn the tap on again and check the flow. If it drips or dribbles slowly you have a blocked tap (can't remember if they have an internal filter). If it runs nicely I'd check the carb out. ____________________ a.k.a 'Geri'
| cb1rocket |
| cb1rocket |
 Posted: 19:42 - 05 Mar 2010 Post subject: |
help!  |
| temeluchus |
| cb1rocket |
| cb1rocket |
| cb1rocket |
| jamiemc |
 jamiemc Derestricted Danger
| cb1rocket |
| cb1rocket |
 Posted: 19:14 - 09 Mar 2010 Post subject: |
yes! yes! yes! thank f*ck for that!!
Thinking it was fuel related all along but actually it was the ignition switch being naff!
grrr new ignition switch on order!!
Thanks for the tip Jamiemc  |
| jamiemc |
The last post was made 16 years, 4 days ago. Instead of replying here, would creating a new thread be more useful? |
