DT 125 Drive sprocket
MartZ0r
PostPosted: 21:24 - 09 Mar 2010    Post subject: DT 125 Drive sprocket Reply with quote
hey guys, im trying to replace a sprocket on my DT 125 (1990), i was wondering if the drive sprocket on the engine is reverse thread to undo it like most engines? i cant get the bugger off and the engine is currently stripped waiting for a rebuild.
Paddy Blake
PostPosted: 21:39 - 09 Mar 2010    Post subject: Reply with quote
Does it have a tab washer on it to stop it coming undone.
MartZ0r
PostPosted: 21:41 - 09 Mar 2010    Post subject: Reply with quote
cheers guys
i already flattened it, il have to try my breaker bar.
neil.
PostPosted: 09:40 - 10 Mar 2010    Post subject: Reply with quote
I had similar trouble with the front sprocket on my YBR. Is the DT's held on with 2 bolts and a plate washer? I ended up rounding off a bolt head and the only thing that got the bugger off was an Irwin Bolt Grip socket. Much to my amazement, it got the bolt unscrewed on the first attempt after I'd tried a hex socket and mole grips to no avail - fantastic bit of kit. Thumbs Up
PostPosted: 09:59 - 10 Mar 2010    Post subject: Reply with quote
The best way to get stubbern buggers off is a crocdile wrench (I think it's called that it's spring loaded and the harder you turn it the harder it grips) and a fuck off bar.
The last post was made 15 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 46.71 Kb
