Play in the throttle cable.... Where do you tighten it?
Gazz
PostPosted: 16:11 - 10 Mar 2010    Post subject: Play in the throttle cable.... Where do you tighten it? Reply with quote
Got a wee bit of play in the cable. When you turn the throttle, there is a wee bit play before the cable actually pulls.
Where do you tighten the cable ?
At the hand grip or where the cable moves the mechanism ?
IE - This bit:
https://faq.f650.com/GSFAQs/Photos/FuelInjectorPhotos/ThrottleCableGSConnection.jpg
Cheers in advance.
PostPosted: 16:52 - 10 Mar 2010    Post subject: Reply with quote
Doesn't look like you can adjust it at the engine end, so do it up at the handlebar. There should be a little bit of free play so that when you turn the bars from lock to lock, the bike doesn't rev up on its own.
pa_broon74
PostPosted: 17:05 - 10 Mar 2010    Post subject: Reply with quote
Looks to me as if the screw at the very top of the picture will adjust the tension on the cable.
Didn't catch anything.
PostPosted: 17:21 - 10 Mar 2010    Post subject: Reply with quote
Pretty sure that's the idle control screw.
YZFR1-Dave
PostPosted: 17:26 - 10 Mar 2010    Post subject: Reply with quote
hey mate, check out this video!
this helped me when i wanted to do mine for the first time Very Happy
https://www.youtube.com/watch?v=_NGz3Fw9s0g
pa_broon74
PostPosted: 18:21 - 10 Mar 2010    Post subject: Reply with quote
Mmm...
I rather suspect you are correct.
I faffed around with mine for ages, ended up getting a replacement cable. The adjuster was at the handlebar end for me, the cable goes through a hollow tube which is threaded at one end allowing you to turn it each way thus adjusting the cable. I could never get it right though.
Gazz
PostPosted: 18:24 - 10 Mar 2010    Post subject: Reply with quote
Thanks for that.
Got it sorted now.
Vrrrrrrroooooooooom !
The last post was made 16 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 52.87 Kb
