Play in the throttle cable.... Where do you tighten it?
Gazz
PostPosted: 16:09 - 10 Mar 2010    Post subject: Play in the throttle cable.... Where do you tighten it? Reply with quote
Got a wee bit of play in the cable. When you turn the throttle, there is a wee bit play before the cable actually pulls.
Where do you tighten the cable ?
At the hand grip or where the cable moves the mechanism ?
IE - This bit:
https://faq.f650.com/GSFAQs/Photos/FuelInjectorPhotos/ThrottleCableGSConnection.jpg
Cheers in advance.
yuri2085
PostPosted: 18:47 - 10 Mar 2010    Post subject: Reply with quote
Hand grip until it runs out, then at the mechanism. Main reason is that it's easier to do at the grip.
iooi
PostPosted: 19:57 - 10 Mar 2010    Post subject: Reply with quote
There is supposed to be some play in the cable......
Usually around 3 m/m
Ditto
PostPosted: 20:00 - 10 Mar 2010    Post subject: Reply with quote
You want to set it so it wont rev when you turn the handlebars to full lock.
I just tighten it at full lock till it revs then back off a bit.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
PostPosted: 21:37 - 10 Mar 2010    Post subject: Reply with quote
Depends how much slack you like in your cable.
Personally I like very little, but I imagine if you're constantly doing U turns then you'd prefer more.
Pete.
PostPosted: 22:04 - 10 Mar 2010    Post subject: Reply with quote
If it revs at all on full lock then it will fail the MOT. Last thing you want is to have unexpected power when making a tight turn.
a.k.a 'Geri'
himlar
PostPosted: 20:05 - 13 Apr 2010    Post subject: Reply with quote
hi ive got a speedfight 100 04 plate and my throtle cable has come loose from near the spak plug end(similar to pick on these posts)could i fit back myself?also would it stop my bike from starting as im having start problems also?
The last post was made 16 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 50.6 Kb
