sprockets
grandmasterbo...
PostPosted: 13:05 - 11 Mar 2010    Post subject: sprockets Reply with quote
yea i was just wondering as i have to change my chain and sprockets i know u can make the top end/ acelleration change i was wondering which sprockets id have to change to make it do what
suzuki CS50 roadie (exploded) Gilerea Runner VX 125 (sold)
CBR125 rw6 (crapped itself and died) YBR 125 2004 (its okay)
Blue_SV650S
PostPosted: 19:55 - 11 Mar 2010    Post subject: Re: sprockets Reply with quote
If you want to lower revs for a given speed, you need to go up teeth on the front or down teeth on the back (or both)
If you want faster acceleration and willing to sacrifice some top end, then smaller front and/or larger rear.
The ratio difference works out about 3:1 ... i.e. you can achieve about the same effect changing either 1t on the front or 3t on the rear ...
Unless you are after drastic changes, I'd stick to +/-1t change on the front (OR +/-3 on rear). If you change the front 1t, chances are the stock length chain will still be ok. You will probably need a different length chain if doing 3 on the rear however ... Thumbs Up
HTH!
grandmasterbo...
PostPosted: 13:42 - 12 Mar 2010    Post subject: Reply with quote
well it max's about 80 if i push it and pretty much lay on it and i hardly do that as bytime it gets there in where i need to be so i dont mind losing top end i jus want it to get to 70 faster tho im having a scorpion full system on soon so im assuming the exaust will give back some of what i lose ?
PostPosted: 13:46 - 12 Mar 2010    Post subject: Reply with quote
While lower gearing might make it accelerate quicker in a particular gear you will have to change up earlier. Other than in first you can probably gain the same effect from just using a gear lower.
alone
PostPosted: 14:39 - 12 Mar 2010    Post subject: Reply with quote
Basicly Kickstart is telling you to rag -the-shit out of your wee bike Smile I wouldn't bother with the new system, save the money for a larger bike! It'll be worth the wait.
Bikes; '06 Triumph Sprint ST 1050 (for sale) - '95 BMW R1100GS
The last post was made 16 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 45.44 Kb
