Indicator troubles DT 125
Imonster
PostPosted: 20:16 - 11 Mar 2010    Post subject: Indicator troubles DT 125 Reply with quote
Indicators have been removed for a few months, and were put back on today. They were playing up before they were taken off the bike and were removed to get it through the MOT.
Indicators wont flash now, and they'll only light up (but again, not flash) when the bike is revved. 2003 model if that makes a difference.
My instinct is the flasher relay is dead, but has anyone got a better idea/something obvious I've missed?
All advice gratefully received...
Those who make peaceful revolution impossible will make violent revolution inevitable.
PostPosted: 20:33 - 11 Mar 2010    Post subject: Reply with quote
Everytime i've had these symptoms it's been due to the flasher relay.
DRZ-400sm
finpos
PostPosted: 20:43 - 11 Mar 2010    Post subject: Reply with quote
Assume you have no electric start, in which case you battery was a bit stuffed a few months ago and now is completely stuffed.
jump leads + car battery is the quickest way to confirm if this is right.
f.
Imonster
PostPosted: 21:07 - 11 Mar 2010    Post subject: Reply with quote
Interesting...thank you Mr. Green
The bike is something of an oddity (for me) in that when you turn the ignition into the on position, nothing happens. No neutral light on the dash, no indicators (if they were working), zip. Bike is kickstart only.
Assumed it was normal for a DT125 as have never owned one - though my old DT50 I had man moons ago used to show a neutral light when the ignition was in the on position before the engine was running.
Should the DT125 be showing some electrical power before the bike is kicked into life?
Despite this quirk, the bike will always kick into life, 99% of the time on the first kick, and has never had any issues while it's running.
Thank you to Truxx as well
PostPosted: 21:42 - 11 Mar 2010    Post subject: Reply with quote
When you turn the ignition on it should have a neutral light and an oil light come on.
You should also hear the powervalve servo do it's test which it does EVERY time the ignition is switched on.
If you're battery is completely dead you won't have any ignition lights and you won't hear the powervalve servo.
First thing i'd do is what finpos said,start with the basics...
DRZ-400sm
finpos
PostPosted: 21:52 - 11 Mar 2010    Post subject: Reply with quote
Battery is indeed completely stuffed. The ignition does not run off the battery but off the alternator so the bike starts quite happily off the kickstart. Once it's started you get a little bit of power out of the alternator which is enough to power small things like the neutral lamp but not enough to power the indicators.
f.
Imonster
PostPosted: 22:02 - 11 Mar 2010    Post subject: Reply with quote
Thank you again!
Still got headlight and tail light though? Albeit fading as the revs drop...
PostPosted: 22:06 - 11 Mar 2010    Post subject: Reply with quote
Lights also run from the alternator. Thumbs Up
DRZ-400sm
finpos
PostPosted: 22:38 - 11 Mar 2010    Post subject: Reply with quote
Yes, just to confuse everybody, you'll probably find on a small bike the alternator has three sets of coils in it connected to three separate circuits:
One runs the CDI exclusively (usually called self exciting ignition)
One is wired through the reg/rec to charge the battery, the battery is then used to run some of the secondary electrics on the bike, e.g. indicators, horn, warning lamp, brake lights. With a knackered battery, you'll find none of these work properly. All this stuff should work with the ignition switched on.
The last one pumps rough AC straight to the Headlight and tail-light, this is confusingly called direct lighting and why the headlight won't work with the ignition off and fades at idle.
f.
Imonster
PostPosted: 23:48 - 11 Mar 2010    Post subject: Reply with quote
ITT, Doug learns about alternators....
Cheers Thumbs Up
The last post was made 16 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 62.64 Kb
