Author |
Vinyardo |
 Vinyardo Scooby Slapper
 Posted: 13:06 - 12 Mar 2010 Post subject: Bandit 600 - draining water from carbs? |
Hi, my '99 Bandit won't start after sitting for a while (turns over, but won't start). Someone mentioned that it could have water in the carbs and there is a drain hose under the engine to remove water - any idea where this is located?? I've looked in the Haynes manual but it's not much help!
Any ideas will be much appreciated!
 ____________________ --| Current bike: |--
--| Previous bikes: Honda CB500 -- KTM Duke 390 -- Honda CBR1000RR7 Fireblade -- Honda CBR600 FX -- Suzuki Bandit 600 -- Yamaha TTR250 -- Suzuki GN125 |-- |
Back to top |
Kickstart |
Back to top |
Vinyardo |
 Posted: 14:02 - 12 Mar 2010 Post subject: |
Thanks Keith, I'll give it a try and hope that sorts it - but like you say, it may not be the problem!
Back to top |
Vinyardo |
 Posted: 08:14 - 15 Mar 2010 Post subject: |
Draining the carbs didn't help - I checked the plugs and there is no spark on any of them, so the problem seems to be electrical.
I've charged the battery and checked the cables and connections, but nothing seems obviously worn.
Any ideas what the culprit could be? CDI? Coils?
Cheers
Back to top |
Ditto |
 Ditto Nearly there...
Back to top |
Vinyardo |
Back to top |
Ditto |
Back to top |
Kickstart |
 Posted: 09:43 - 15 Mar 2010 Post subject: |
No spark could be down to several things. Wrecked plugs (possible but unlikely all 4 would be shot at once), faulty coils (again not that likely both would be gone at once), faulty crankshaft pickup, faulty wiring, faulty cdi unit.
When you are cranking the engine over, do the revs register on the rev counter? If so that would suggest that the cdi unit is getting a signal.
Back to top |
Vinyardo |
Back to top |
Kickstart |
 Posted: 10:08 - 15 Mar 2010 Post subject: |
Suggests it is getting a signal, but would expect it to give a sensible (low) reading rather than jump around.
There are various things that will prevent a spark. Ignition switch, kill switch and (most likely) sidestand switch / clutch switch / neutral switch (ie, a combination of those will kill the ignition to stop you riding off with the stand down).
Back to top |
Vinyardo |
Back to top |
Kickstart |
Back to top |
Vinyardo |
 Posted: 11:39 - 15 Mar 2010 Post subject: |
I'll give them a check and see how it goes then. Never used a multimeter before so should be interesting  ____________________ --| Current bike: |--
Back to top |
Kickstart |
Back to top |
Vinyardo |
Back to top |
The last post was made 15 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
