| Snowy |
 Snowy L Plate Warrior
| Shaun |
 Shaun Likes 'em bent
 Posted: 09:03 - 02 Jul 2004 Post subject: |
It just sounds like a normal flat spot in the revs to me, probably normal and just there because of emissions laws!
| bikedudextrm |
 bikedudextrm Traffic Copper
 Posted: 19:29 - 02 Jul 2004 Post subject: |
The Mito power valves have an adjustment to adjust the gap between the valve in the closed position and the piston. Get this wrong and the valve can touch the piston when things get hot, and taking the valves out to clean them then reassembling the whole lot will affect this gap (especially if you reuse the gasket).
However check the power valve adjustment cables before you do any more.
| cagiva gezzer |
 Posted: 19:52 - 02 Jul 2004 Post subject: |
Check the aligment of the pully wheel marks and the marks on the housing.
The pully wheel has two marks on it and one should be aligned with the mark on the housing when the revs are below 7250 and then the wheel should turn at above 7250 and the other mark should align with the mark on the housing.
The pully wheel is under a rubber flap marked "CTS" on the right hand side of the cylinder. The operation of it can be checked by turning the ignition on and off.
You can get the manual from www.cagivaproject.com ____________________ "because one stroke isnt enough and four strokes waste two" |
| Snowy |
There is a gap of 6 years, 237 days between these two posts... |
| cagiva evolution |
 cagiva evolution L Plate Warrior
The last post was made 15 years, 120 days ago. Instead of replying here, would creating a new thread be more useful? |
