| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 01:28 - 09 Feb 2010 Post subject: The machining competition has started... and now finished |
just in case theres anyone interested... plus a documentation of it for personal reference, and so i can use the info while its fresh in my head for the portfolio to go with it
a while back i made a thread about my slightly optimistic idea to machine an entire engine in 5 weeks... those 5 weeks being 1 day a week for about 3.5 hours a day.
so basically making an entire engine in about 17.5 hours...
anyway, i've started this today, and in the first day have managed to make a very crude cam and the piston.
Due to the limited time i have available, i'm blitzing out the parts as quickly as i can, and sorting out the fitting of them when it comes to assembling it, and tidying up the finish etc when i get round to it.
heres the brass cam (1 of 2, second yet to be made) and aluminium piston.
https://img684.imageshack.us/img684/9884/08022010010.jpg
https://img237.imageshack.us/img237/2447/08022010009.jpg
the cam diameter is 20mm with a 13mm lift
piston diameter is 50.5mm x 55mm, bored out as thin as possible without the risk of it collapsing, with an internal step so as to support the gudgeon pin.
the engine wont run. it's just there to be an example of a DOHC engine and show the operation and valve timing.
considering the opposition (coursemates) are making things like universal joints, fly presses and sine bars, i think i've got a fair shot at aceing this if i can pull it off and finish it.
suggestions welcome. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Paulington |
 Paulington World Chat Champion
| MaybeGuy |
 Posted: 13:22 - 09 Feb 2010 Post subject: |
the plan was to make it out of aluminium, then do a 1/4 section of the barrel to show the inside and all the valves working etc.
i know i could make it out of better materials, but brass and aluminium are the fastest ones to do. the only polymer i have available is white or black nylon. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| MaybeGuy |
 Posted: 13:11 - 16 Mar 2010 Post subject: |
made a shit load of progress since starting this (and funnily enough i'm almost finished). I'll be honest when i say the head i made isn't great, but the rest if it goes together perfecetly.
My plan was to make a 2 piece crank with an interference fit to press it together, but i managed to machine one out of a solid piece of brass which worked pretty well. that took 2 attempts the first one was finished, but as the machine was slowing down and i was backing off the tool, i caught it and snapped it. cant repeat what i said. loudly.
https://img96.imageshack.us/img96/2725/01032010055r.jpg
next was the crank case. started by drilling and reaming a 24mm hole through a block of ally, chopping off a 20mm section of it, then boring what i had left out to 70mm, then milling off the top leaving me with a very rough (now tidied up) crank case. the chopped off section would be bolted back on.
https://img63.imageshack.us/img63/8503/01032010056.jpg
https://img59.imageshack.us/img59/8449/01032010054.jpg
conrod was pretty simple. milled the flats on a round bar so it fitted between the crank webs, then drilled a hole for the big end, then cut a section out. i threaded it all the way through so it didnt clamp down on the big end, stopping it moving.
https://img31.imageshack.us/img31/7815/01032010058.jpg
https://img21.imageshack.us/img21/2681/01032010057.jpg
Piston was just drilled and had a peice of stainless bar through it. looked like this assembled loosely.
https://img694.imageshack.us/img694/4305/01032010059.jpg
the barrel... nothing ingenuitive here, just a bored out hole to fit a piston. same as any other engine.
https://img24.imageshack.us/img24/5271/01032010060.jpg
made a second cam
https://img10.imageshack.us/img10/2641/01032010061.jpg
then i cracked on with the head and sort of made it up as i went along.
started by reaming holes for the crank bearings (3/4 section to give me more working space but still hold a bearing) then milling the inside down to allow space for the cam lobe and valve movement.
the hole you can see is drilled into the valve guide to act as an inlet/exhaust.
springs theived from the stores, and as a temp measure, the screws are through it.
https://img710.imageshack.us/img710/5782/15032010078.jpg
flip it over and you can see the recesses made for the valves
https://img185.imageshack.us/img185/5540/15032010079.jpg
tatty as fuck, but it all moves nicely.
then finally, the near finished piece...
just need to fit the bearings and find a way to bolt it all together.
https://img202.imageshack.us/img202/8366/15032010077.jpg
with a couple of weeks to go, i'll use one week to attach it all together, then use the final week to tidy it all up so it looks all jazzy and stuff.
bear in mind, that this entire project was done using no specific measurements, and a ''that'll do'' attitude, the whole thing was made using this as a schematic drawing.
https://img40.imageshack.us/img40/2803/07092009057.jpg
i've also ordered an 8 tooth, 2 x 16 tooth 6mm pitch sprockets with a length of chain, and all bearings, so they should be here in time for next monday.
suggestions x ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| c_dug |
 c_dug Super Spammer
| Fawbish |
 Fawbish World Chat Champion
 Posted: 13:44 - 16 Mar 2010 Post subject: |
Actually pretty mint  ____________________ "Oh....it looks like Average Joe's is forfeiting the match!" - "Yeah, its a risky strategy but lets see if it pays off for 'em Cotton." |
| Carl_steveo |
 Carl_steveo World Chat Champion
| Minty |
 Minty World Chat Champion
| Robby |
 Robby Dirty Old Man
| MaybeGuy |
 Posted: 16:30 - 16 Mar 2010 Post subject: |
i was thinking bolting a minimoto carb on and a bit of flanged copper pipe on the inlet/exhaust.
Sparkplugs not a bad idea. Ill try and find out what thread it needs to be (probably a metric fine?).
I doubt ive got enough time to make and mount a flywheel, but thats been noted too. I reckon 1 week is just about enough to finish it off and resolve any fuckups that come to light.
Bit late for a finned barrel dont you think?
leccy motor would be cool, but then theres the time to mount it and get hold of one. Maybe earlier, but at the mo i dont think theres time
im going to keep it afterwards, because fuck if im pumping £40 of bearings sprockets and chains into it for nothing. So i reckon ill see if i can make it run in my own time. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| smegballs |
 smegballs World Chat Champion
| Ben. |
 Ben. World Chat Champion
 Posted: 17:50 - 16 Mar 2010 Post subject: |
how many horses do you reckon that bad boy is kicking out then? bout 50bhp?
on a serious note. did you bother to work out the cc? and as said just bolt a starter motor to a fly wheel. you can fiddle about with how big a cog to put on it so that you can make it spin over really slowly.
well done. looks cool!  ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| MattHirst |
 MattHirst World Chat Champion
 Posted: 18:21 - 16 Mar 2010 Post subject: |
I can see why all of you are impressed with it. But, and no offence, it looks like crap to me
Coming from a mechanical engineer, i use lathes and milling machines day in, day out and make far more complex components in a fraction of the time it's taken you to make them so you've not really rattled them off. Not to mention the poor finishes on most of the components (work out your speeds and feeds boi ) and the general poor craftsmanship, you've not even broken the corners on any of them for fooks sake
When you made the thread/post a while ago about making an engine, i thought it was actually going to resemble an engine and possible even work to some extent, i'm dissapointed little boy! Only reason you haven't got bad karma is because you have a cool name  ____________________ It's all fun and games until someone gets hurt, then it's bloody hilarious!!! |
| MaybeGuy |
 Posted: 19:08 - 16 Mar 2010 Post subject: |
| MattHirst wrote: | I can see why all of you are impressed with it. But, and no offence, it looks like crap to me
When you made the thread/post a while ago about making an engine, i thought it was actually going to resemble an engine and possible even work to some extent, i'm dissapointed little boy! Only reason you haven't got bad karma is because you have a cool name  |
i doubt you could do much better in 17.5 hours.
Shit troll btw ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Carl_steveo |
| Ariel Badger |
 Ariel Badger Super Spammer
| MattHirst |
 Posted: 19:49 - 16 Mar 2010 Post subject: |
| mattsprattuk wrote: | | MattHirst wrote: | I can see why all of you are impressed with it. But, and no offence, it looks like crap to me
Shit troll btw |
I could write a couple of programs and get all that done on a CNC in in a couple of hours. I could do the same on manual machines in a few hours more. Certainly wouldn't take me 17.5 hours and it would be far higher quality
I'm failing to see how that is trolling aswell
CHR15 - One of the lads made the air line engine thingy when i was training, i ended up making a work support for a milling machine (will get some pics when i'm discharged from hospital ) and started on the vice but ran out of time as i started at the company.
carl_steveo - There are 2 options really. Look through engineering magazines etc and find someone selling off a small lathe/milling machine you can put in your garage (you will probably need a 3 phase feed installing or get an invertor) and teach yourself how to turn/mill.
The other option would be to do an apprenticeship like i did, takes around 4 years and can be quite boring at times but once you're qualified it's not to bad, money isn't bad either. Obviously if you're a wrinkly old fart then the 2nd option isn't really applicable  ____________________ It's all fun and games until someone gets hurt, then it's bloody hilarious!!! |
 Posted: 20:40 - 16 Mar 2010 Post subject: |
| SoND |
 SoND World Chat Champion
 Posted: 20:49 - 16 Mar 2010 Post subject: |
Very nice work.  ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| neatbik |
 neatbik World Chat Champion
 Posted: 21:15 - 16 Mar 2010 Post subject: |
Nice one Matt. Im in a similar position as you, part of my college course is engineering based. I know how frustrating it can be to have severe time restraints, plus im sure i could work a lot quicker if i didnt have the totally over the top safety nazi rules and regs that colleges require - hence im sorting out a small lathe for my workshop  |
| Carl_steveo |
The last post was made 16 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
