| Ditto |
 Ditto Nearly there...
 Posted: 01:54 - 18 Mar 2010 Post subject: To anyone confused with where to fit Restrictor Kits |
Ok, so i know when I was looking into bikes with no knowledge of even what a carb did i had no clue as to where the restrictor kit would go.
Ive found quite a good picture though which demonstrates their location.
This will be the same for most if not all kits that use discs for restricting down to 33bhp, be it 2 cylinder, 4, whatever.
They always go into the inlet rubbers. Do not know of a kit consiting of discs which doesnt.
If your bike does not use discs for restricting this will not be of help, as they will fit into another part of the carb.
So you have your kit like this. They will look similar for all bikes, a metal washer with a hole in to restrict the intake flow.
https://i290.photobucket.com/albums/ll267/yankee_doodle_01/banditwashers.jpg
Locate the carbs which should be easy, and you will have to loosen the clips securing them at both the airbox side and engine side. For this example im using my Bandit. The airbox can be unbolted and slid back. Once this is done slide the carbs back so there is a gap to reach into the rubbers.
https://img502.imageshack.us/img502/2451/restrictorlocation.jpg
Pop the kit into the rubbers, and there you have it.
This shows what they look like in position.
https://img169.imageshack.us/img169/3976/restictorcopy.jpg
Slide the carbs back on, make sure they line up, bolt the airbox back on and secure the clips.
And there you have it. Easy enough to do, and wont need to pay the garage silly amounts. ____________________ CG 125 > Bandit 600 > CBR 600 FY > Street Triple R |
| everyreasonto |
 everyreasonto Nitrous Nuisance
 Posted: 22:35 - 23 Mar 2010 Post subject: |
Awesome thanks, i'm getting a zxr soon that needs restricting. I'm good with a spanner and I refuse to pay the garage £200 for it  |
There is a gap of 226 days between these two posts... |
| HD |
 HD World Chat Champion
 Posted: 00:37 - 05 Nov 2010 Post subject: |
Is it really that simple?
And does your bike have 4 carbs?  ____________________ Rusty '02 Vito Camper + CBR600F3 |
 Posted: 01:53 - 05 Nov 2010 Post subject: |
Usefull info there. But have you actually done it yet?
In my experience, life ain't usually quite so simple.
For one thing. You are unlikely to be able to move the carbs far enough back to detach them from the inlet manifold with the airbox rubbers still attached. Once they're off, there is usually JUST enough space to slide the carbs out sideways. The airbox rubbers are usually a complete bastard to put back on again afterwards.
It's also thas case that on any bike with a few miles on, the rubbers go pretty stiff. It takes quite a hard pull to get the carbs off the inlet rubbers. It can also be very hard to insert the washers without heating said rubbers to soften them up a bit (dunking them in boiling water is a favourite).
I have also yet to see an inline, multi-cylinder jap bike on which "unbolting the airbox" didn't involve removing a hell of a lot of componants to get at it. Even then you can only move it about half an inch back. Different for downdraught carbs or V configured engines because the airbox does unbolt and lift off.
What this boils down to is you usually have to remove the carbs altogether, and probably the inlet rubbers too in order to fit the restrictor washers. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Suntan Sid |
 Posted: 08:48 - 05 Nov 2010 Post subject: |
| stinkwheel wrote: | Usefull info there. But have you actually done it yet?
What this boils down to is you usually have to remove the carbs altogether, and probably the inlet rubbers too in order to fit the restrictor washers. |
Got to agree with Stinkwheel.
Let me give you an idea how, bleedin', difficult it can be to get, older, carb rubbers off.
Had a problem with my CBR a couple of weeks ago, carbs needed cleaning so I thought I'd replace the rubbers at the same time.
Tank off, air box off and cables disconnected, slackened jubilee clips on rubbers.
The bike was on the side stand. "Easing" the carbs off the block, as it says in "Haynes", just doesn't happen. After half an hour of heaving and pulling I managed to move the bike a meter down the drive.
Then resorted to a, very large, flat blade screwdriver to prize, the one and only accesible rubber off, this took about 10 mins of scraped knuckles and much swearing, to move it a couple of millimeters.
After a another 10 mins of heaving, the end carb rubber gave me 5mm then let go. Once that one had shifted the rest followed suit.
The rubbers were hard as nails! |
| truslack |
 truslack World Chat Champion
| G |
 G The Voice of Reason
| Ditto |
The last post was made 15 years, 345 days ago. Instead of replying here, would creating a new thread be more useful? |
