Delivering Startmenu Icons
Colin Edwards
PostPosted: 11:36 - 18 Mar 2010    Post subject: Delivering Startmenu Icons Reply with quote
Delivered icons..
We have the need to deploy section based shortcuts to Windows users on our network. These shortcuts are to be delivered in a folder in the start menu. So far I have automated the process with login script (by group policy) and got the shortcuts to the users XP desktops but struggling with the start menu part. I can get the icons to deliver anywhere but can’t create the directory in the users start menu
I have tried a MKDIR %userprofile%\Start Menu\new folder and other command like it in the script but the folder is not created..
Anyone know an easy way to do this?
Thanks
CE
T1z3R
PostPosted: 11:41 - 18 Mar 2010    Post subject: Reply with quote
try sending them to 'all users' rather than specific users.
duck my sick!
Hetzer
PostPosted: 12:13 - 18 Mar 2010    Post subject: Reply with quote
Group email them with a readme telling them how to place them themselves. Laughing
Colin Edwards
PostPosted: 12:59 - 18 Mar 2010    Post subject: Reply with quote
Tried this.. And using proper C:\ path as well.. Still nothing..
Colin
chrisw
PostPosted: 14:31 - 18 Mar 2010    Post subject: Reply with quote
Not wishing to state the obvious, but you do know that if there is a space in a file/folder path, the whole path has to be encapsulated in double-quotes (shift+2)?
Also, I can't remember, but who runs the login script? Is it executed as a local system account or by the user who is logging in? If it's the later then you need to make sure they have the permission to create the folders.
Neorion
PostPosted: 14:54 - 18 Mar 2010    Post subject: Reply with quote
pretty decent VBS in here for raping Thumbs Up
https://www.experts-exchange.com/Programming/Languages/Visual_Basic/VB_Script/Q_25111545.html
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
PostPosted: 15:32 - 18 Mar 2010    Post subject: Re: Delivering Startmenu Icons Reply with quote
You did try putting it inside the programs directory in the start menu directory, yes?
djr
PostPosted: 16:16 - 19 Mar 2010    Post subject: Re: Delivering Startmenu Icons Reply with quote
Colin Edwards wrote:
Delivered icons..
Thanks
CE
Why not do it through group policy / Folder redirection?
Then you just have to create a share on a file server / domain controller (make it read only so users can't change your shortcuts Razz) and do it that way Smile
It's under User configuration > windows settings > folder redirection
then options for desktop, start menu, application data and my documents.
smegbrains
PostPosted: 12:57 - 20 Mar 2010    Post subject: Reply with quote
Sounds like you're doing it with the copy command in a batch file, you should try xcopy as there's no faffing about with mkdir then.
If you use %userprofile% in a startup script it will fail as there is no user logged in, so you can only copy to all users unless you run it as a login script.
Put the shortcuts in required folders into \\server\share\shortcuts\ and make sure if you're running as a startup script that "Authenticated Users" is in the access list with read only access.
All Users (Startup or login script):
@Echo Off
xcopy "\\server\share\shortcuts\*" "C:\Documents and Settings\All Users\Start Menu\Programs\" /s /y /q
Single User (Login script only):
@Echo Off
xcopy "\\server\share\shortcuts\*" "%userprofile%\Start Menu\Programs\" /s /y /q
That should do trick.
Current Bike: Honda CBR 600F
Ex Bikes: Suzuki GX 125
Colin Edwards
PostPosted: 16:36 - 20 Mar 2010    Post subject: Reply with quote
I can get the icons to appear (on the desktop so far with VB).. I just cant create a folder in the start menu for the icons..
CE
Colin Edwards
PostPosted: 16:45 - 20 Mar 2010    Post subject: .. Reply with quote
Using VB scripts to action text files with the icon type and action..
Attached are the VB and txt script examples (vb renamed)
Thanks
CE
Colin Edwards
PostPosted: 20:46 - 23 Mar 2010    Post subject: Reply with quote
Any more ideas?
The last post was made 16 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 73.86 Kb
