Digi speedo setting - way off
Blue_SV650S
PostPosted: 21:49 - 19 Mar 2010    Post subject: Digi speedo setting - way off Reply with quote
I got a digi speedo on my KTM 250
i.e. one like this ...
https://www.motorcyclenews.com/upload/174744/images/300x200/939942748633.jpg
Ok, so I set it up (21" wheel) and it just seemed stupidly OTT speed reading ... long story short, I decided to calibrate it using 2 sat navs (side by side).
To get the speed to be the same as the sat-navs (presume they are there or there abouts) I had to dial in 1345 ... now that is a long way off ....
How can it be that far out?!!? Thinking
carvell
Scuttler
PostPosted: 21:55 - 19 Mar 2010    Post subject: Reply with quote
It may not be picking up the wheel rotation on every rotation properly.
What you want to do is line your tyre valve with a crack in the pavement, wheel your bike forward so that the tyre valve is back at the bottom where it was before, then measure from the crack in the pavement to where it is now. That's the easiest way of measuring your wheel circumference (which is what the speedo wants).
Yamaha TDM 850
Blue_SV650S
PostPosted: 22:12 - 19 Mar 2010    Post subject: Reply with quote
But it was reading way FASTER (which would require more RPM/picups).
2205 relates to a diameter of ~27.6" (probably about right for a tyre on a 21" rim). I did measure the circumference with a tape BTW and it wasn't far off the 2205 (can't remember exact value)
1345 circumference relates to a wheel of ~17" dia (~13" rim??) that is a BIG difference Shocked Confused
PostPosted: 22:17 - 19 Mar 2010    Post subject: Re: Digi speedo setting - way off Reply with quote
I presume 1345 is the circumference in mm. Strangely that appears to be pretty close to the circumference of a 17" wheel (without tyre).
Presume it works off a magnetic pickup? Where is that mounted?
Blue_SV650S
PostPosted: 22:23 - 19 Mar 2010    Post subject: Re: Digi speedo setting - way off Reply with quote
Yes, circumference in mm
As for positioning I can't see that would make any difference - we are counting revolutions and multiplying it up to get a speed ... it is only going to pass the sensor once a revolution regardless of distance from hub hub!!! Wink
Anyway, the magnet is in the disc and the pickup is screwed into the caliper mount .. (stock KTM position BTW, not my idea)
PostPosted: 22:27 - 19 Mar 2010    Post subject: Reply with quote
Would be if one of the disk mounting bolts is magnetic. Also some chance of interference from the ignition system.
Blue_SV650S
PostPosted: 22:39 - 19 Mar 2010    Post subject: Reply with quote
I see the thinking of the magnetic bolt, but if you double 1345, you get 2690 ... NOT 2205 ...
Can't find a pic of my exact disc, but here is one that demonstrates the point ....
The eyelet down the bottom takes a magnet ...
https://www.ktmcyclehutt.com/ktm-parts/productimages/54809060300_lg.jpg
As for the ignition system ... that is an interesting thought ... I could always 'cut' the motor when in motion and see if the speed suddenly changes ... Thinking
PostPosted: 22:44 - 19 Mar 2010    Post subject: Reply with quote
Would think it might register if you just revved the engine, but you never know.
Magnetic disk bolts or bobbins are not unknown. Think some Bimotas used them as standard.
KevTM
PostPosted: 09:26 - 20 Mar 2010    Post subject: Reply with quote
No idea but my Vapor one uses a small magnet on the front disc and you calibrate it by entering the circumference of the wheel (preferably with your weight on the bike).. there's a few ways of doing it but either way mine seems perfect (well as close to as poss.). I did hear some people say that with the vapors they get crazy readings above 20-30mph... could possibly be a damaged sensor/pickup doo-dah ?! Confused
The last post was made 16 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 65.39 Kb
