GSX-R calipers- Why 2 sizes of piston?
Dibble
PostPosted: 00:17 - 20 Mar 2010    Post subject: GSX-R calipers- Why 2 sizes of piston? Reply with quote
I'm fitting some calipers from a 1996(?) GSX-R 600 to my Moto Guzzi V50 and the pistons seem to be 2 sizes i.e. each caliper has 2 large and 2 small pistons.
Does anybody know why and will "running them backwards " have any effect?
The Guzzi has its calipers in front of the forks not behind so the disc rotates past the big piston then the small rather than the GSX-R where it runs small then large.
I can swap the forks over to a more conventional set up if needed and no I don't know why the calipers are in front Smile
cheers
Dibble
MaybeGuy
PostPosted: 00:56 - 20 Mar 2010    Post subject: Reply with quote
i know some of the SRADs used 4 pot and others (the 750) used 6 pot? obv the 6 pot would be smaller pistons.
Dibble
PostPosted: 08:18 - 20 Mar 2010    Post subject: Reply with quote
I'm having a problem explaining this but each caliper has one set of 27mm pistons and one set of 30mm pistons. I think this means one set will squeeze the disc harder but what effect does this have??
Gawain
PostPosted: 09:32 - 20 Mar 2010    Post subject: Reply with quote
Its probably something to do with balancing the braking force at the leading and trailing area of the pad. I think most modern sport bikes have that type of setup.
lonner
PostPosted: 10:55 - 20 Mar 2010    Post subject: Reply with quote
it was all about giving more feel to the brakes and pad wear when this different size pistons started many moons ago Thumbs Up
think you will be fine however you fit them Thumbs Up
hth
PostPosted: 11:04 - 20 Mar 2010    Post subject: Reply with quote
Yea, I think it was worked out that due to the way the wheel was spinning etc that one part needed more force than the other.
However I suspect they'll still be a decent upgrade and that the way they are mounted (the 'wrong' way) will probably be more of a general disadvantage than the individual pistons being the wrong way around.
PostPosted: 11:34 - 20 Mar 2010    Post subject: Reply with quote
Gawain is right. The leading edge of the pad has more braking effect. So to even it out the leading piston is smaller to apply a bit less pressure and even out the braking effect.
Not sure there are any braking disadvantages to having the calipers forward of the forks. Should get more airflow over the calipers to keep them cooler. However with the different size pistons expect the pads to wear oddly at least.
Marmalade
PostPosted: 11:43 - 20 Mar 2010    Post subject: Reply with quote
If your brakes are linked, as in if you hit the front it applies the back a little as well, the smaller pistons would be for the secondary action.
The last post was made 16 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 57.58 Kb
