| markrolls88 |
 markrolls88 Renault 5 Driver
| P.addy |
 P.addy Red Rocket
| markrolls88 |
| cb1rocket |
 cb1rocket World Chat Champion
| markrolls88 |
| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 22:08 - 21 Mar 2010 Post subject: |
Check your wiring first mate, could be something simple like a shite earth then you would've just wasted money!
Is it a reasonably old cg? Do your lights etc work fine even without the engine running?
As said previously, a wiring diagram is a must, i couldn't tell you how many times mines been useful but its been a hell of a lot!
You should be able to find the main earths pointed out in the diagram, if they're all fine then go more indepth into your switches etc. any 'dodgey' connections you come accross along the way, just re-do them to narrow down the cause of the problem.
Hope this helps, electrics are a bugger but its great when YOU fix it yourself for free
Rob
EDIT: Just read your first post, if your lights are dim etc. it does sound like something is draining all your power (ie. bad earth) do as suggested above
| Alexio |
 Alexio World Chat Champion
 Posted: 22:10 - 21 Mar 2010 Post subject: |
LOL. When I saw the title "help cg125 power problem" I laughed and thought to myself, don't I know it  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| rob_scott92 |
| P.addy |
 P.addy Red Rocket
| markrolls88 |
| P.addy |
 P.addy Red Rocket
| markrolls88 |
| Robby |
 Robby Dirty Old Man
 Posted: 12:22 - 10 Apr 2010 Post subject: |
What you are describing are the classical symptoms of a flat battery. I know you fitted a new one and you say you charged it, but give some more detail here.
My bike runs a battery of a similar capacity to a CG. I had a fairly flat battery, which took over 24 hours on my clever charger to fully charge. I don't know what kind of charger you're using, but if it's a clever bike specific trickle charger then leave it plugged in at least overnight. I wouldn't use a dumb type car charger, it supplies a lot of current which can overheat a bike battery. It's worth noting that a brand new battery still requires charging. Assuming a conventional lead-acid battery, they are supplied dry and the acid is added. You leave it for about half an hour, then connect a trickle charger and leave it overnight.
After you have done this, if the symptoms persist, it's time to check connections. Battery connections first, make sure the battery terminals are free of white corrosion and the leads show clean, shiny metal. If they are dull then this is a sign of corrosion, and you should clean them back with emery paper or wire wool and add a light smear of copper grease before reassembly.
If this doesn't fix it, then the frame earth points and starter solenoid connections are the next. Again, disconnect and check of corrosion, clean up to get bright shiny metal, then reassemble with a smear of copper grease.
Electrical components are quite tough in general, the weaknesses are in earth connections and bad batteries. Starter solenoids can suffer from corrosion inside (they act like a heavy duty relay), but can be dismantled and cleaned.
If you don't have emery paper, get some. It removes rust and leave a clean surface, whilst sandpaper or wet and dry, which look similar, never give such good results. They tend to score the surface and not remove rust so quickly. |
| markrolls88 |
The last post was made 16 years, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
