| WULL |
 WULL Guest
 Posted: 13:43 - 26 Jul 2002 Post subject: DERESTRICTIN AGAIN |
WHEN I TOOK OFF MY CARB INLET PIPE THERE WAS NO GOLD PLATE JUST A PLASTIC INSERT WITH REEDS ON IT DOES THIS GO BACK IN ,I SEE ON THE VIEW IN THE GUIDE IT DOESNT APPEAR TO BE REFITTED OR MENTIONED,ALSO CAN YOU SUGGEST A SUPPLIER FOR BIG BORE HEADS?  |
| Demonic69 |
 Demonic69 The Pink Rhino
| Guest |
 Guest
| zaknafien |
 zaknafien
| Hunter |
 Hunter Nitrous Nuisance
 Posted: 19:58 - 27 Jul 2002 Post subject: |
With a 92 NSR you should not have any restrictions in place.
What is the top speed of the bike? is the 6th gear effective i.e. can you continue to accelerate on the 6th?
The reed block (the piece of plastic with the reeds stuck on) must be replaced as it is necessary for the normal function of 2-stroke bikes!
Check the carb to see if the throttle slide has any restriction.. i.e. does the throttle valve open up completely when the accelerator is fully twisted?
Also check the exhaust flange (the bit that sticks on to the engine), and see if there is a 'ring' inserted (welded) on to make the hole smaller than it could be.
Thats about it.  |
| Demonic69 |
| Guest |
 Guest
| Typhoon XR70 |
 Typhoon XR70 Two Stroke Sniffer
 Posted: 19:15 - 29 Jul 2002 Post subject: |
PM Tuning do big bore kits. Visit www.pmtuning.co.uk and send them an E-Mail  |
| Demonic69 |
| themaku |
 themaku Derestricted Danger
| Hunter |
 Posted: 20:04 - 30 Jul 2002 Post subject: |
Yeah mine is 13 on the front sprocket too. The problem is putting 14 will make it accelerate slower, but give a better top-speed!! My 6th gear seems full power cause I've hit 90mph and still had more juice (i think i can hit about 100+mph). Check you rear sprockets too, these are equally important!
the o-ring is not in-between the exaust and cylinder, but welded onto the opening of the exhaust pipe (cylinder head end).
Good luck!!
| themaku |
| Hunter |
 Posted: 18:12 - 01 Aug 2002 Post subject: |
maybe you got a pair of race pipes on! Anyhow the weld being broken does not sound too good. I would suggest getting it shown to a professional!
The last post was made 23 years, 286 days ago. Instead of replying here, would creating a new thread be more useful? |
