What grit paper do i need for this job?
Misc
PostPosted: 06:05 - 25 Mar 2010    Post subject: What grit paper do i need for this job? Reply with quote
Morning,
On my car there's a small part of the bodywork that has no lacquer as you can see were it's pealed too. I plan on adding lacquer to this area but only have a touch up brush so understand the finish won't be smooth. So my question is, what grade paper will i need to sand the new lacquer to a smooth finish?
Does it scratch? Can the scratches of a fine grade be buffed out? And how many layers of lacquer would you suggest?
Cheers. Thumbs Up
Robby
Dirty Old Man
PostPosted: 15:02 - 25 Mar 2010    Post subject: Reply with quote
1200 or higher grade wet and dry is what I use to flat back paint. I would go for two coats of lacquer than a very careful rub back with 1200 or higher, used very wet.
Read the can for lacquer, the halfords stuff only recommends two coats.
I think there are special things available to rub back lacquer.
Misc
PostPosted: 15:18 - 25 Mar 2010    Post subject: Re: What grit paper do i need for this job? Reply with quote
Misc wrote:
Morning,
Cheers. Thumbs Up
Thanks for that. Will get some 1200 then. I lacquered the patch of bodywork today with a touch up stick & looks better but i'll wait til i get the sand paper so i can rub down before the second coat.
Cheers. Thumbs Up
The last post was made 16 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 35.97 Kb
