Good makes of brake disc
PostPosted: 23:46 - 25 Mar 2010    Post subject: Good makes of brake disc Reply with quote
Not after anything 'performance' just discs that are as good as OEM discs and decently priced. I figure EBC, any others?
MaybeGuy
PostPosted: 23:47 - 25 Mar 2010    Post subject: Reply with quote
galfer
PostPosted: 23:52 - 25 Mar 2010    Post subject: Reply with quote
All Bike Engineering or ABE...
PostPosted: 00:03 - 26 Mar 2010    Post subject: Reply with quote
I always though galfer where dear but they seem to be the same as EBC.
I'm not convinced with ABE, I had a pair of there fork stantions that pitted after a year, eventualy they rechromed then for me which took an age to do the finish is still not brilliant.
The Tot
PostPosted: 21:33 - 07 Apr 2010    Post subject: Reply with quote
A bit of a bump so sorry for bringing it up.
Galfers, www.calsport.co.uk are doing a reasonable deal on their speed kits... you get about £100 off rrp.The only difference is that the discs are of the older wavy design. If you brakes are warped and need replacing, then galfer are about the same price as OEM if they're on sale. EBC's tend to be on the tier below. As always, i'd try to source OEM before I try for some aftermarket parts.
Galfer; first impressions (i've got HEL braided lines on the front too on a standard master cyl). The brakes work well in the wet. Less mass on the front is not really noticable. What I have found is that the galfer pads don't half generate brake dust! My calipers are covered in the stuff! Braking performance, there isn't any fade after prolonged use. After a gentle squeeze you can feel the lever feel harder.
On the whole, a worthy alternative. NB, Galfer and Braking both applied for the patent for wavy discs together and were pretty much the same company in the early years... however, galfer generally tend to be cheaper.
Never argue with autism
Clanger
Stirrer
PostPosted: 21:41 - 07 Apr 2010    Post subject: Reply with quote
Only heard of EBC.
Reppyboyo
PostPosted: 22:01 - 07 Apr 2010    Post subject: Reply with quote
Armstrong discs are quite good for the price.
Really wear your pads down quick though.
TheDonUK
PostPosted: 00:15 - 08 Apr 2010    Post subject: Reply with quote
I somewhat agree with the criticism of ABE, I got a pair of discs from them but they had such bad burr's on the edge i had to spend a good 30 mins with sandpaper to get it down to acceptable levels. They seem to work fine, but theres just something not quite 100% about the place, even though the guy seemed pretty decent...
Dibble
PostPosted: 01:20 - 08 Apr 2010    Post subject: Reply with quote
ABE are cheap but not very cheerful.......
I was in there about a year ago looking for bits for a project and as often happens in bike places the conversation wandered. After about 5 mins a bloke in a brown stock coat came out from the back and told his employee and ME off for wasting time Shocked Shocked
As for their quality I fitted some of their discs and some genuine Suzuki pads to a DR600 and the pads shredded the discs, bits of swarf 1mmx1mmx3mm came off, softer pads sorted it.
BanditsHigh
Worse than a woman
PostPosted: 05:45 - 08 Apr 2010    Post subject: Reply with quote
Many moons ago I fitted new EBC discs to my MKI 1200 Bandit ... never felt that they were as good as the OEM!
MarkJ
PostPosted: 09:33 - 08 Apr 2010    Post subject: Reply with quote
I've been looking for some and found TourMax on M and P. Clicky. They're the cheapest I've found.
Has anyone else used these before?
BanditsHigh
Worse than a woman
PostPosted: 12:07 - 08 Apr 2010    Post subject: Reply with quote
^^^ Price rises considerably depending on bike Thumbs Up
MarkJ
PostPosted: 12:53 - 08 Apr 2010    Post subject: Reply with quote
Still the cheapest though. For my Hornet, per disc:
£115 for TourMax
£135 for EBC
£156 for Galfer (off that other website posted near the top)
PostPosted: 13:12 - 08 Apr 2010    Post subject: Reply with quote
Bit cheaper but never used them:-
https://blackshadow-uk.com/default.aspx
MarkJ
PostPosted: 13:24 - 08 Apr 2010    Post subject: Reply with quote
That reminds me, I've heard good things about Stealth:
https://www.stealthproducts.co.uk/discs.html
The last post was made 16 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 85.47 Kb
