Chain clicking noise - clutch?
DynamiteBoy
PostPosted: 19:58 - 26 Mar 2010    Post subject: Chain clicking noise - clutch? Reply with quote
Hi All,
When riding the bike produces a loud clicking noise from chain. The tempo matches speed (ie faster I go, faster the clicks).
I have adjusted to tight spot, lube chain regularly and have a scott oiler fitted.
If the clutch is pulled in (changing gear) the noise stop, also stops if coasting down hill in neutral. Could chain clicking be related to clutch?
Another point to make is that with bike in gear and clutch pulled it seems like more effort is needed to push (can feel resistance from drive).
Just looking for some good leads / advise before I go tinkering.
"I dont like my Job anymore - I dont think i'll go" OfficeSpace
Honda CG125 (sold) - Kawasaki GPZ500s (sold) - Kawasaki Zephyr 550 (sold) - Kawasaki er6n (current work horse)
alun111
PostPosted: 20:37 - 26 Mar 2010    Post subject: Reply with quote
Check your front sprocket, mate.
I had this problem on my hornet. It turned out the front sprocket was excessively worn (hooked teeth) and I think what was happening was the chain was jumping off the front sprocket and hitting the bash guard thing. This eventually resulted in my chain having a missing roller and the same pin having a hole through it. I changed the chain and sprockets as a set and the problem went.
neil.
PostPosted: 22:44 - 26 Mar 2010    Post subject: Reply with quote
Check final drive first as that's the easiest job.
A similar thing happened to me, could also feel the clicking as knocking. Adjusting a bit more slack in the chain helped for a while, but then it returned. I initially suspected it was bearings in the output shaft failing. Turned out my master link was warping and weakening on one side but by such a small amount I couldn't see it, until the chain snapped whilst I was on a busy dual carriageway. Shocked How old is your chain/how many miles has it done? Is it a decent make? Are you using a split-link?
Clutches can also wear down and get notches in their basket and the friction plates can wear out as well. Not sure if that produces knocking as it's never happened to me yet (still on the original clutch components and the bike has done nearly 25'000 miles), touch wood!
alun111
PostPosted: 08:21 - 27 Mar 2010    Post subject: Reply with quote
Hi,
Don't think it would, you could get a knock if the damping springs/rubbers in the back of the clutch basket were worn but I think this would only happen on initial acceleration, and it would only be once.
Aka Matt
PostPosted: 11:01 - 27 Mar 2010    Post subject: Reply with quote
Sounds like a new c&s is on the cards for you. Check both sprockets and also measure how much your chain has stretched as per what is stated in your bike service manual. Had the same thing on my bandit which turned out to have a knackered chain and a rather fecked front sprocket.
Current bike(s): 2016 Tuono 1100 Factory, 1998 Hornet 600
Previous: 1998 YZF600R Thundercat, 2001 Bandit 600, 2002 GSX-R 600 K2, 2011 Tuono R, 2013 Z1000SX
DynamiteBoy
PostPosted: 13:45 - 29 Mar 2010    Post subject: Reply with quote
The chain has lots of play even after adjusting to tight spot so this needs replacing. I'll do C&S together.
I was also very surprised by amount of thick grud around front sprocket, must of scrapped out half a handful of the stuff (Note to self, don't use anymore wax chain spray).
This chain is an O-Ring design. Its only done 7k. My last 'originally' fitted chain latest 12k and I did not have a scott oiler at time. Should I invest in x-ring or other chain type to ensure more miles?
The last post was made 16 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 49.86 Kb
