dirtbike making blue smoke
zxcvbnm
PostPosted: 05:32 - 27 Mar 2010    Post subject: dirtbike making blue smoke Reply with quote
hi i recently had my crank go on my 2000 honda xr100 dirtbike, so i took the top end off the 2000hondaxr100 and put it on a 1985xr100 bottom end i had around. but ever since i did that it makes blue smoke when its cold or at other odd times, but not when going fast. i dont no y this is anyone know?
ride it like you stole it!
hmmmnz
PostPosted: 05:58 - 27 Mar 2010    Post subject: Reply with quote
blue smoke indicates that you are burning oil,
so probly duff rings,
or a scored barrel
the humans are dead
I kick arse for the lord
Blue_SV650S
PostPosted: 09:45 - 27 Mar 2010    Post subject: Reply with quote
If it is predominantly on startup, then it is more likely to be the valve stem oil seal.
random_rob
PostPosted: 11:07 - 27 Mar 2010    Post subject: Reply with quote
check oil level, putting too much in causes this problem! Be sure to check level when the bike is upright.
zxcvbnm
PostPosted: 15:51 - 27 Mar 2010    Post subject: dirtbike making blue smoke Reply with quote
well the bottom end of the engine i put the top end on was kinda dirty from sitting outside for awhile, so there might have got dirt in it, with would of caused a scored cylinder, but does that seen i will have to re bore it again? because i already re bored it two oversizes like 5 mouths ago.
zxcvbnm
PostPosted: 15:52 - 27 Mar 2010    Post subject: dirtbike making blue smoke Reply with quote
and what do you mean by "duff" rings?
random_rob
PostPosted: 19:09 - 27 Mar 2010    Post subject: Reply with quote
duff: knackered or dodgey
zxcvbnm
PostPosted: 03:24 - 28 Mar 2010    Post subject: dirtbike making blue smoke Reply with quote
anymore suggestions on this problem?
Cigaro
PostPosted: 10:45 - 28 Mar 2010    Post subject: Reply with quote
Did you check the oil level as said?
It must be burning oil somehow; as said it's probably a worn valve seal or the rings. There's not really any other way for oil to get into the combustion chamber Thumbs Up
cb1rocket
PostPosted: 11:33 - 28 Mar 2010    Post subject: Reply with quote
is this a 2 stroker?
zxcvbnm
PostPosted: 17:01 - 28 Mar 2010    Post subject: dirt bike making blue smoke Reply with quote
is a 4 stroke,and could the oil be going though the head gasket, becuase i dident buy a new headgasket when i did the rebuild...........
random_rob
PostPosted: 17:16 - 28 Mar 2010    Post subject: Reply with quote
yes, but back to the origional question. Has it got TOO much oil in it? because if it has it will burn the excess oil, and there might not even be a problem with the engine itself.
Or even has it got the correct oil in it, the right viscosity and brand to what the service manual says.
The last post was made 16 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 70.64 Kb
