How do you remove these clips?
Misc
PostPosted: 22:06 - 28 Mar 2010    Post subject: How do you remove these clips? Reply with quote
Evening,
Wanting to replace a few parts on the car but i'm confronted by these weird looking clips. Quite annoying too as i'm guessing they're not reusable. So, how do i get the buggers off?
https://img38.imageshack.us/img38/4715/61608131.jpg
MaybeGuy
PostPosted: 22:09 - 28 Mar 2010    Post subject: Reply with quote
they dont tend to use them anymore for ''safety reasons'' which i think is bullshit.
anyway, the only way is to cut them off. i suppose mole grips would work if you just wiggled it till it fatigued and snapped (everyone has a set of them, but its not ideal)
either way, you'll want to be replacing the pipe afterwards if its a vital one.
Ichy
PostPosted: 22:42 - 28 Mar 2010    Post subject: Reply with quote
What makes you think that? I don't think you can get them for DIY but I see hundreds of them being used on new engines each day.
I use a screw driver to expand them or cut off the smaller ones with wire cutters.
Misc
PostPosted: 23:24 - 28 Mar 2010    Post subject: Reply with quote
Cheers guys, it's for a vacuum hose. The actual clips are much smaller then the one in the photo so i'll give the above methods a go.
MaybeGuy
''safety reasons'' being sharp edges or some shit like that.
the MOD and all contracting companies associated with dont use them for this reason.
MattHirst
PostPosted: 23:28 - 28 Mar 2010    Post subject: Reply with quote
Don't they know what a file anda burr removal tool is?
Come back when you've finished your apprenticeship and you're not just the dogsbody making tea Wink Razz
MaybeGuy
PostPosted: 23:58 - 28 Mar 2010    Post subject: Reply with quote
so you'd cut it, then de-burr it before you removed it? doubt it.
thats like saying ''here, have this knife. but instead of a sheath, have a file so you can blunt it and sharpen it as you use it''.
makes sense
to you
MattHirst
PostPosted: 16:21 - 29 Mar 2010    Post subject: Reply with quote
You don't have to cut it, you can expand/splay it out with a screw driver or somet pliers, no sharp edges then.
I assumed you were referring to the sharp edges on the diameter of the clip, de-burr that and you have no sharp edges.
So yes, makes sense to me. Go back to slowly making inferior products on an m300 lathe Razz
Handsome
PostPosted: 16:42 - 29 Mar 2010    Post subject: Reply with quote
If in doubt...Hammer...
PostPosted: 20:23 - 29 Mar 2010    Post subject: Reply with quote
I usually get the tag end of them in a set of end cutters, grip tight and twist.
I crimp the new ones on with a blunted set of end cutters. Which is essentially what the proper crimping tool is.
I've put on and removed many hundreds of those things when I had a holiday job installing oxygenation systems on fish farms.
The one you have there is called a "single ear pinch clamp". You also get "Double ear clamp" ones which have a crimp at either side and are a bit more secure (but harder to get at both sides of in a tight spot).
The last post was made 16 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 65.42 Kb
