loss of power, xr125
random_rob
PostPosted: 14:58 - 29 Mar 2010    Post subject: loss of power, xr125 Reply with quote
as some of you may remember, my bike wouldnt idle from cold.
someone suggested i adjusted the idling screw.
ive done that, and its perfect now, but when i go to set off or open the throttle, there is no power then it will all come all of a sudden.
is that something to do with the air mixture screw i fiddled with by mistake before i found the idleing screw?
random_rob
PostPosted: 15:01 - 29 Mar 2010    Post subject: Reply with quote
could somebody please give me some hints on how to set the two of them up, as if i was having a fresh start?
richbike
PostPosted: 18:01 - 31 Mar 2010    Post subject: carb setting Reply with quote
Hi,
Haynes or similar should spec the number of turns out for the idle mix screw. But if you dont know try screwing it all the way in, then backing out 1 and a half turns as a starting point.
With the bike warmed up tweak the throttlestop/tickover screw so it idles reliably, then try moving the mix in and out...you want to find the point which increases the idle the most
then back off the tickover screw if its idling a bit high
tedious but relatively straight forwards
use a good screwdriver thats the right size...someone in the past seems to have done mine with a sodding impact driver
cheers
Rich
random_rob
PostPosted: 21:34 - 31 Mar 2010    Post subject: Reply with quote
haha, oh dear.
will have a play tomorrow then at that.
thanks
The last post was made 16 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.99 - MySQL Queries: 13 - Page Size: 39.19 Kb
