| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 12:52 - 29 Mar 2010 Post subject: Brake Caliper Pins!!!!! |
My suzuki SV650 brake pads are being changed - problem
The fecking pin retaining the pads won't come out!
I have heated it, punch, cut in half and punch but its just not going anywhere!
I know a grinding cutting disc is good for cutting, but isn't there one like a grinding drill so i can grind the pins out completely!
My twist drills have all been knackered because of this
help! |
| Kickstart |
 Kickstart The Oracle
| Darth |
 Darth World Chat Champion
| Kickstart |
| chris-red |
 Posted: 13:57 - 29 Mar 2010 Post subject: |
I read the thread title assumed they where siezed and assumed the bike was a Suzuki before I opened the read. Says something about the Suzuki reputation for metal quality ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| Kickstart |
| dodgydog |
 dodgydog World Chat Champion
 Posted: 14:11 - 29 Mar 2010 Post subject: |
Took a day to get the pins out of the rear caliper on my Speed Triple, £12 for two new pins also
Snap on extractors and drills worked in the end
drill very slowly, and use Rocol or similar lube.
Dog ____________________ I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant |
| chris-red |
| Kickstart |
 Posted: 16:04 - 29 Mar 2010 Post subject: |
The front of the 1200 Bandit are similar calipers to the Speed 4 I think. They are decent calipers. Work well and need little maintenance.
The Thunderbird has a twin pot sliding caliper Nissan on the front and on the back. They need a strip down at least every year (pins the calipers slide on stick, pistons stick and the allen key pin to hold the pads in place is a pig to get out even with copper slip on it).
| cb1rocket |
 Posted: 16:05 - 29 Mar 2010 Post subject: |
Hi guys thanks for all replies -
Calipers are front, the pin goes into a blind hole and is retained in place using an R clip.
The pin is firmly wedged possibly because of bi-metallic corrosion so its pretty much welded itself in! Alloy and steel don't mix well!
I'm left with:
One half of pin flushed in the blind hole, and one half of the pin flushed in the opening hole that lets it slide all the way in.
Conclusion no holes at either end!
So what tool could i use? Will a rotary cone grinder work?
Drilling is impossible, i get about 0.5mm then the drill goes blunt, i do use wd-40 as a cutting fluid
Still need answers and help, or i'm stuck to resorting to new a caliper job.
I haven't touched the left but thats probably fucked too
Ta |
| Kickstart |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 17:53 - 29 Mar 2010 Post subject: |
Having read all of this, would I be right in assuming that for future reference, it would be good to dip the ends of the retaining pin in copper slip before fitting it?
I'm not trying to sound like a smug tosser, I'm genuinely curious to see if there's a worthwhile preventative measure, other than by stripping the calipers regularly. Mainly because I've got one of these bikes coming my way in a week and a half... ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| That_Hornet |
 That_Hornet World Chat Champion
 Posted: 17:57 - 29 Mar 2010 Post subject: |
When mine got stuck, i just brought a new caliper.
But the got it out after by easyouts.
Now stuck with a spare caliper
As said, center punch it, then drill very slowly in, the easyouts. |
| Kickstart |
| SlimRick |
 SlimRick World Chat Champion
| TUG |
 TUG World Chat Champion
| Bezzer |
 Bezzer World Chat Champion
| cb1rocket |
 Posted: 22:30 - 29 Mar 2010 Post subject: |
Calipers can't be split in half, I can't seem to find myself a suitable drill bit that will attack the metal for a hole!
Even my black and decker bits have been ruined by trying.
Mole grips - can't use as nothing to grip on to - they are flushed /inline with the rest of the caliper body
| Robby |
 Robby Dirty Old Man
| chris-red |
| Bezzer |
| Kickstart |
| cb1rocket |
 Posted: 22:50 - 29 Mar 2010 Post subject: |
lets say i got the pads out, but the pins were grinded down to body - both side!
I'll try and re drill the alloy side of the body.
But the real problem is that the pin is stuck on the open side and is stuck inside, no amount of punching with a centre punch has got it out
I have been at it 3 hours now! |
| Robby |
 Robby Dirty Old Man
| TUG |
The last post was made 15 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
