Honda tappet spanner size
Robby
Dirty Old Man
PostPosted: 15:14 - 30 Mar 2010    Post subject: Honda tappet spanner size Reply with quote
Now that I have a bike that requires relatively regular valve adjustment, I need to get a good approximation of the right tool.
Bike is a 1980 CB250RSA, with screw and locknut adjustment on rocker arms. The locknut is 8 or 9mm, so I have rings spanners that fit it. The problem is the tappet itself, it's about a 2mm square fitting, and I can't find any spanners that small. I may try a very small socket, but I soubt I have anything that small.
What do you guys use to hold the tiny stem when adjusting the valve clearance?
neil.
PostPosted: 15:37 - 30 Mar 2010    Post subject: Reply with quote
On my YBR I could hold it with my fingers (you could also try a pair of long nose pliers but it's fiddly). I eventually bought the tool for a few quid. Dunno if it will fit your engine though but it is also a square hole of a couple mm in size. Can give you the part number if you want to order it from a Yammy dealer?
PostPosted: 15:43 - 30 Mar 2010    Post subject: Reply with quote
I use my fingers.
yen_powell
PostPosted: 15:54 - 30 Mar 2010    Post subject: Reply with quote
Go to a proper tool shop, one where the people serving are all over 50 and wear brown coats with a ruler sticking out of their top pockets. They will sell you a little 4/5mm open ended spannerthat looks like it is made for Action Man (or whatever size it is, I'll look when I get in tonight). That's what I use on my Honda, along with a 10mm ring spanner for the locknut.
XT1200Z and a DR350 in bits
tatters
Exxon Valdez
PostPosted: 15:59 - 30 Mar 2010    Post subject: Reply with quote
Strange size imperial box spanner has worked for me in the past, like a screw driver with a socket fitted permintaly to the end
DrDonnyBrago
PostPosted: 20:05 - 30 Mar 2010    Post subject: Reply with quote
Me and Bacon used a pair of pliers with tape on the ends to do his CB250 valves, piece of piss tbh. IIRC though there may have been a tool suggested in the manual...
Pliers work fine though with tape to prevent damage to the tappet. Thumbs Up
PostPosted: 20:14 - 30 Mar 2010    Post subject: Reply with quote
I used a long thin spanner that I nicked from my dad's toolbox. I think it was a spoke nipple tool for bicycles.
You might find an ignition spanner that fits :-
https://www.diytools.co.uk/diy/Images/DB_Detail/_26147_139473.jpg
Bru
PostPosted: 22:09 - 30 Mar 2010    Post subject: Reply with quote
A Honda dealer should be able to get one for you. Mine cost about £3, a couple of years ago. It has a proper Honda part number - any competent person at the service desk should find the details for you.
PostPosted: 22:15 - 30 Mar 2010    Post subject: Reply with quote
Fingers for 3 of them. Needlenose for the stubborn one. Its an 8mm locknut. Will butcher a screwdriver next time. i.e 2mm slot with a 45 degree bend.
Pic for illustration purposeshttps://i104.photobucket.com/albums/m174/howlingterror_2006/IMG_0246001-1.jpg
Pat
Robby
Dirty Old Man
PostPosted: 22:23 - 30 Mar 2010    Post subject: Reply with quote
I've done a bit more googling and it seems that it's a 4mm stud, so I've ordered a 3.2/4mm combination spanner that should do it.
The problem is that it's one of those jobs that needs too many hands, seeing as the exhaust rockers have a spring forcing them down onto the valve. Should be able to get the clearances sorted properly now.
PostPosted: 22:52 - 30 Mar 2010    Post subject: Reply with quote
A photo in the Haynes shows a 1/8th (3.1750mm) on the adjuster nut. It isn't a good fit.
Pat
PostPosted: 23:05 - 30 Mar 2010    Post subject: Reply with quote
I've always used pliers.
The last post was made 16 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 73.71 Kb
