| Aleks |
 Aleks Two Stroke Sniffer
 Posted: 16:50 - 31 Mar 2010 Post subject: Depressing Engine (It's a pun) |
Hello everyone, basically I've posted here before a few times, I have a TZR125 (Here's the album of chronological pictures)
https://www.facebook.com/album.php?aid=120336&id=584260891&l=daf708567f
Recently I decided to take the engine out, clean it, put it back in.
I ended up just draining all fluids, replacing them, taking the head gasket off, gazing in amazment at the head of my piston, then putting it back together again
Now it's all back together and I'm having... Well, Issues.
For one I can't find neutral anymore. Literally, the light won't come on ever and I can't feel it anywhere either, and I know you're sposed to move the bike around a bit to move the engine so you can change gears a bit, but I have no rear wheel at the minute (getting a new valve, it's leaky) so I've tried pumping the kickstart to move the sprocket, even then, no neutral to be found
Second problem and more serious is that it won't start.
Fresh fuel, fresh two stroke. I'm sure I put the carb back together right and all the lines go where they should, so as far as I'm concerned the bike has the fuel and air (And after a particularly hard session of trying to kick life into it, black liquid that stinks like petrol starts seeping through the gap between the exhaust port on the engine and the exhaust connection.) Next thing I checked was Spark plug: I took the plug out, plugged it into the HT lead and there's a spark, so I have a spark. Thirdly I've checked for compression by putting my thumb over where the spark plug goes and I feel the compression as it kinda farts through my thumb
So I'm stumped, if I hold the choke on and kick it a few times, I hear the engine turn over about 6 times, the exhaust lets out smoke, but it just dies down... It's like it can't sustain the reaction.
And it's really annoying cause I set out to understand my bike and breathe new life into it Even more annoying now that I can afford to insure, MOT and tax it
Any advice will be muchly appreciated, I'm happy to do any kinda diagnostic you can think of and I dunno, record the results and post a video on the internet or something.
I'm that desperate for this to work. |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Aleks |
| ms51ves3 |
 ms51ves3 Super Spammer
| iooi |
 iooi Super Spammer
 Posted: 17:30 - 31 Mar 2010 Post subject: |
Take plug out and get a spanner on end of crank. That should allow you to get down to 1st by rotating enging back and forth a bit. Once 1st is found netural should not be hard to find.
As to the light. Have you connected all the wires up to the switch and in the right order.
This could also be why it wont start if it has anything like a side stand or clutch switch and its not connected up correctly. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Gazdaman |
| Aleks |
 Posted: 17:47 - 31 Mar 2010 Post subject: |
| richbike |
 richbike Two Stroke Sniffer
| Gazdaman |
| Vincent |
 Vincent Banned
 Posted: 21:00 - 31 Mar 2010 Post subject: |
| Aleks |
 Posted: 00:41 - 01 Apr 2010 Post subject: |
Re-reading everything Gaz has said is pretty much pointing towards the head gasket needing a change, the only thing that's making me doubt that is the compression I feel when I put my thumb over the spark plug hole.
Then again, thinking about it, the compression from me turning the engine over slowly with the kickstart is nothing really, compared to the pressure going on in there when the kaboom happens.
My money is now on Head Gasket Fail. Thanks Gaz  |
The last post was made 16 years, 108 days ago. Instead of replying here, would creating a new thread be more useful? |
