Speedo not working
Kaph
PostPosted: 22:06 - 29 Mar 2010    Post subject: Speedo not working Reply with quote
Hey guys,
Finally beginning to get the bike useful after a rebuild and various other fixes, next on the list is the speedo.
The odometer works and counts up, but the speedo itself does nothing. The speedo's analogue, but the cable to it looks digital? I wouldn't quote me on that, but I haven't been able to have a proper look. S'on the agenda for tomorrow.
Unfortunately the headlight fairing, which is attached to the speedo, looks a pain to get off. Still, worth a shot.
Secondly, if all else fails, are aftermarket speedo's legal and MOT-passable? Had a look on eBay, but 160mph cut-off seems a bit OTT for a 50cc tbh.
Thanks!
cloric_tzr
PostPosted: 00:03 - 30 Mar 2010    Post subject: Re: Speedo not working Reply with quote
Kaph wrote:
Hey guys,
Thanks!
where is the speedo attached to wheel? or gearbox (highly unlikely)
try unscrewing from wheel check the end out spin with a drill if poss. then same at other end.
just to let you no if its digital there will be a series of conector blox or 1 if old style it will be cable. if it is connector blox scrap my 1st idea. just 4 reference what bike is it?
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
Kaph
PostPosted: 22:06 - 31 Mar 2010    Post subject: Re: Speedo not working Reply with quote
cloric_tzr wrote:
Kaph wrote:
Hey guys,
Thanks!
Okay took the headlight and fairing off today, speedo cable is attached to wheel. Seems digital, just a group of 3 cables. Around 5/6 cables also going into speedo, guessing those are the like status indicators.
I'm guessing because the odo works it's the mechanism in the speedo itself?
It's a 'Generic Trigger SM50'. Haha.
DrDonnyBrago
PostPosted: 10:48 - 01 Apr 2010    Post subject: Reply with quote
Could still be the speed sensor part in the wheel, the odometer runs from another cable most likely coming out of your crank case.
Remove the speedo cable from the speedo then take the speedo sensor part from the front wheel and spin it v quick, does the speedo end of the cable turn?
Next replace the speedo end of the cable and remove the sensor end, spin that v quickly (i.e. using a battery drill) does the speedo register speed?
If neither works, your cable is shafted. If the speedo turns then the speed sensor is likely shafted and if the cable turns with the speed sensor but the speedo doesnt register speed then the speedo is likely shafted.
Hopefully, the cable is bust or one of the connections at either end it bust and itll be cheap to replace
Photos help Thumbs Up
DrDonnyBrago
PostPosted: 10:49 - 01 Apr 2010    Post subject: Reply with quote
Ah:
Your speedo is V unlikely to be digital if the sensor is on the wheel Very Happy
Again, photos help Thumbs Up
Kaph
PostPosted: 19:38 - 17 Apr 2010    Post subject: Reply with quote
As an update, fixed pretty much everything else on the bike apart from this.
I've had the entire front assembly off, and still can't get the speedo to work. Unfortunately the odometer isn't working either now, so I suspect that's my fault from knocking something.
The cable from the wheel attatches to a connector into the clocks, it's got three wires coming out of it. I'll grab some pictures tomorrow.
I rang up about new clocks but at £147quid, just no. Spent a ridiculous amount on the bike already.
I'd like to get the odometer working at least, it might be the cable I guess. How specific are they to the bike?
The last post was made 15 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 51.02 Kb
