ACF50 uses
moto
PostPosted: 18:59 - 03 Apr 2010    Post subject: ACF50 uses Reply with quote
Can ACF50 be used as a chain lubricant.
PostPosted: 20:41 - 03 Apr 2010    Post subject: Re: ACF50 uses Reply with quote
I wouldn't personally as it seems to attract dirt - it makes it easy to remove when it sticks, but seems an ideal way to make a grinding paste.
Darth
PostPosted: 21:29 - 03 Apr 2010    Post subject: Reply with quote
At £13.50 a can i can think of better and more economical alternatives!
moto
PostPosted: 08:41 - 04 Apr 2010    Post subject: Reply with quote
Good point G.
I am yet to find a chain lube that I am satisfied with.
My manual says to use engine oil but as soon as I go out for a ride it sprays everywhere.
What do you lot use?
PostPosted: 10:02 - 04 Apr 2010    Post subject: Reply with quote
Engine oil mostly. Got some 'dry lube', which doesn't fling at all, but not sure it's actually lubricating very well.
A well set up chain oiler is the best way I reckon - minimal fling if you've got it set up correctly.
After using engine oil on road bikes I will often stick an old towel over it with the engine running to absorb most of the initial 'fling' - I am very careful to ensure it doesn't crab my fingers and stick them through the sprocket which is exactly the sort of thing that often happens to people that do this
Masked
PostPosted: 10:10 - 04 Apr 2010    Post subject: Reply with quote
I've never used anything that doesn't spray all over the place, the best stuff I've used I think is Holts chain lube, picked it up from Halfords and seems to stick to the chain quite well but does end up with grit etc in it eventually. An alternative to using specific chain lubes is gearbox oil for scooters, costs about £8 for a bottle but lasts longer than anything coming out of a can.
The way I've always done it is to put the lube on after cleaning the chain with paraffin after a ride and then leave it for about 15 minutes to let it soak into the chain and then just wipe off any excess. My uncle used to take his chain off and leave it in a tin of warm engine oil, he reckoned it stopped it flying off but a bit of a hassle
neil.
PostPosted: 14:29 - 04 Apr 2010    Post subject: Reply with quote
KasWear wrote:
What about having the back of the bike raised and running the engine until the access is gone, that's what i used to do when i had my Chopper. Thumbs Up
I do this to help dry the chain after cleaning it with paraffin, then I dry off whatever is left with kitchen paper and brush engine oil over it, leave for 5-10 mins and run the wheel off the engine to fling off excess, but it's only good for bikes with a centre stand or if you have a paddock stand. Just need to make sure the bike is 100% stable and you or somebody else aren't gonna go near that moving chain/sprocket. Thumbs Up
I use ACF50 on electrical connectors that are exposed as it will keep them from corroding, and yes it is a dirt magnet. I have also used it to clean up screw threads that have corrosion on them (whitish stuff) before wiping it off and reassembling. Seems to attack/dissolve the corrosion nicely.
KevTM
PostPosted: 16:22 - 04 Apr 2010    Post subject: Reply with quote
Used to use dry lube but use old filtered engine oil now, chain seems to last longer plus it's generally a hell of a lot cleaner.. usually apply with a toothbrush.
Noxious89123
PostPosted: 14:18 - 05 Apr 2010    Post subject: Reply with quote
After cleaning my chain, I use a rag, soaked with a bit of scottoil and run the chain through it, turning the wheel by hand. Then use a dry part of the rag to run the chain through to get the excess off.
People always seem to use alot more lube than needed, and this is why it flings off. You only need a very fine film of oil. A scottoiler means that my chain doesn't get dirty and become dry.
The last post was made 16 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 68.93 Kb
